9.3 to 9.10 upgrade broke one of my Arrays/Volumes
Scharbag
smartctl -a /dev/da20
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Crucial/Micron RealSSD C300/M500
Device Model:	 Crucial_CT480M500SSD1
Serial Number:	14331D8B1F36
LU WWN Device Id: 5 00a075 10c2b1f36
Firmware Version: MU05
User Capacity:	480,103,981,056 bytes [480 GB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	Solid State Device
Form Factor:	  2.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sun Jan 15 12:52:01 2017 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x80)	Offline data collection activity
					was never started.
Self-test execution status:	  (   0)	The previous self-test routine completed
					been run.
data collection:		 ( 2235) seconds.
capabilities:			  (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	  (   2) minutes.
Extended self-test routine
recommended polling time:	  (  37) minutes.
Conveyance self-test routine
recommended polling time:	  (   3) minutes.
SCT capabilities:			(0x0035)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   100   100   000	Pre-fail  Always	   -	   0
  5 Reallocated_Sector_Ct   0x0033   100   100   000	Pre-fail  Always	   -	   0
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   17848
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   36
171 Program_Fail_Count	  0x0032   100   100   000	Old_age   Always	   -	   0
172 Erase_Fail_Count		0x0032   100   100   000	Old_age   Always	   -	   0
173 Wear_Leveling_Count	 0x0032   096   096   000	Old_age   Always	   -	   134
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000	Old_age   Always	   -	   21
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033   000   000   000	Pre-fail  Always	   -	   8219
183 SATA_Iface_Downshift	0x0032   100   100   000	Old_age   Always	   -	   0
184 End-to-End_Error		0x0032   100   100   000	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
194 Temperature_Celsius	 0x0022   071   056   000	Old_age   Always	   -	   29 (Min/Max 0/44)
196 Reallocated_Event_Count 0x0032   100   100   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   100   100   000	Old_age   Always	   -	   0
202 Percent_Lifetime_Used   0x0031   096   096   000	Pre-fail  Offline	  -	   4
206 Write_Error_Rate		0x000e   100   100   000	Old_age   Always	   -	   0
210 Success_RAIN_Recov_Cnt  0x0032   100   100   000	Old_age   Always	   -	   0
246 Total_Host_Sector_Write 0x0032   100   100   ---	Old_age   Always	   -	   51911182937
247 Host_Program_Page_Count 0x0032   100   100   ---	Old_age   Always	   -	   1654105725
248 Bckgnd_Program_Page_Cnt 0x0032   100   100   ---	Old_age   Always	   -	   2649136468
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 17848		 -
# 2  Short offline	   Completed without error	   00%	 17842		 -
# 3  Short offline	   Completed without error	   00%	 17836		 -
# 4  Short offline	   Completed without error	   00%	 17830		 -
# 5  Short offline	   Completed without error	   00%	 17824		 -
# 6  Short offline	   Completed without error	   00%	 17818		 -
# 7  Short offline	   Completed without error	   00%	 17812		 -
# 8  Short offline	   Completed without error	   00%	 17806		 -
# 9  Short offline	   Completed without error	   00%	 17800		 -
#10  Short offline	   Completed without error	   00%	 17794		 -
#11  Short offline	   Completed without error	   00%	 17788		 -
#12  Short offline	   Completed without error	   00%	 17782		 -
#13  Short offline	   Completed without error	   00%	 17776		 -
#14  Short offline	   Completed without error	   00%	 17770		 -
#15  Short offline	   Completed without error	   00%	 17764		 -
#16  Short offline	   Completed without error	   00%	 17758		 -
#17  Short offline	   Completed without error	   00%	 17752		 -
#18  Short offline	   Completed without error	   00%	 17746		 -
#19  Short offline	   Completed without error	   00%	 17740		 -
#20  Short offline	   Completed without error	   00%	 17734		 -
#21  Short offline	   Completed without error	   00%	 17728		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Unless you purposely truncated most of the useful data from your SMART results, you smartctl -a should return all of the above information if it has true physical access to your hard drives.
Using an eSATA enclosures may place another piece of hardware in between ZFS and your drives, effectively nullifying the benefit of ZFS. To properly house your drives in an external enclosure, you need to use an exclosure with a proper SATA/SAS expander.
There is a really nice section in the hardware guide that discusses eSATA and SATA port multipliers:
SATA Port Multipliers
These really deserve a category of their own. They’re universally crap. Beyond that, there are a few additional reasons why they would never be a good choice:
  •  Intel SATA, which is the only 100% reliable SATA solution out there, explicitly does not support port multipliers.
    o Even WD knows this. When they released a hybrid 120GB SSD/1TB HDD, they could not use a port multiplier to connect them both to a single SATA port. They were forced to use a custom controller that handled both spinning rust and NAND flash and mapped the first LBAs onto flash and the rest onto disk.
  •  The most common application for SATA port multipliers are eSATA chassis. Those are also universally crap in their own right, with issues from bad cooling to dodgy PSUs.
  •  They’re cheap alternatives to SAS expanders. They’re just a cash grab.
  •  Many also do even more horrible stuff, like hardware RAID for the enclosures mentioned
    above – yes, on tiny chips with essentially no resources. Yes, they’re a disaster.
While FreeNAS is, well, free, their are certain hardware considerations that should be followed. If you choose not to follow clearly communicated requirements, then the risk is 100% yours.
Cheers,
James L
					was never started.
					been run.
					command.
					power-saving mode.
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Cheers,
Thanks for the response. Yes I did truncate the results in the earlier file. Here is the complete detailed output. It certainly appears to me that the HDDs on the SATA Expander support SMART capability, but maybe I'm not reading it right.
James
  • HWDiagsDetailed.txt
Scharbag
Probably going to have to chalk it up to something that 9.10.x does not like about the eSATA swarf then. Not a great technical answer but alas, there are some things that might be best to avoid with FreeNAS.
James L
Alas, it was my only option for this machine to support 6 drives.
