Azani Ramsan
- Jun 2, 2014
As seen in above screenshot, content does not load in anything such as disk list, volume list, smart test list, NTP server list, anything that list records. Looks like JS error to me. I tested using all kind of browser and the result is still the same. The NAS is working fine, the GUI does not.
For diagnosing, I will list my recent activities below :
1. Migrating from old board into a new board, this is not the problem as this problem also exists while I'm using the old board
2. Changing the UPS
3. Removed and reinstalled Transmission plug-in.
4. Reconfigure network interface setting
Other than that, as long as I remembered, the GUI still works fine.
The only times when I access/modify anything in freenas that not using its GUI (through ssh) is when I need to move personal files and folder as root, only for file management, simple commands such as mv, mkdir, rm.
Also, there was a time when my transmission is messed up so I have to fix the json setting file by editing and removing json file through ssh (doing some modification at first, but apparently does not solve the problem, so I resort to deleting the config file, then it works), but that was it, nothing else.
Forgot to mention, I also occasionally check the condition of my UPS through GUI console.
And no, I don't have any spare freenas USB but I do made config backup every 2 months or so. I intend to upgrade to 9.3 after I get my encryption key backups. As far as I know, I cannot do this without accessing the volume details which is impossible with this problem.
Someone had similar problem with the GUI ?
