No ZFS pool. Four SATA CD drives
The USB drive that I am trying to connect isn't being used for anything. I just want to connect it and have it be recognized at the correct capacity.
From dmesg:
pid 1528 (syslog-ng), uid 0: exited on signal 6 (core dumped)
ugen1.2: <JMicron JM20336 SATA, USB Combo> at usbus1
umass0 on uhub0
umass0: <Bulk-In, Bulk-Out Interface> on usbus1
umass0: SCSI over Bulk-Only; quirks = 0x8100
umass0:7:0: Attached to scbus7
da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
da0: <ST8000VN 0022-2EL112 > Fixed Direct Access SCSI-2 device
da0: Serial Number A16888888888
da0: 40.000MB/s transfers
da0: 1339429MB (2743151280 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
GEOM_PART: integrity check failed (da0, GPT)
ugen1.2: <JMicron JM20336 SATA, USB Combo> at usbus1 (disconnected)
umass0: at uhub0, port 1, addr 2 (disconnected)
da0: <ST8000VN 0022-2EL112 > s/n A16888888888 detached
(da0:umass-sim0:0:0:0): Periph destroyed
umass0: detached
umass0 on uhub0
umass0: at uhub0, port 4, addr 2 (disconnected)
umass0: detached
