Fairly new to FreeNAS, have been playing around for a few months. I have a bunch to read about zfs, vdev etc but I wanted to post a somewhat generic question about how best to utilize the hardware that I have.
I just purchased 8 2TB 7200RM drives that will go on my IT flashed HBA. Running the wizard creates a single ZFS volume (hope I'm using the right terminology) and I then add a share to that for SMB.
Before I start putting any kind of real data on it (going to kick it around a bit to understand how it works), what is the preferred configuration for my 8 drives? The enclosure is maxed out at 8 so I won't be adding anything, but I'm considering a 12 bay enclosure for the future. It would not be the end of the world if I had to re-create, as all of this data is either backups (already existing in 2 other places), or replicated off-site data (existing in 2 other places), so other than time, no great concern for data loss right now.
I've just started reading about zfs, vdevs etc, but confess i don't know much yet.
I keep hearing about multiple vdev's which can allow for more expansion?
Right now array is just under 10TB but would like to see if it's possible to grow if I were to move to 12 bay or would I just re-build on new platform?
A few pointers would be helpful.
Thanks,
Roveer
Thanks,
Roveer
