Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE #0 r+2315ea3: Fri Dec 20 12:48:50 PST 2013
root@build.ixsystems.com:/tank/home/jkh/checkout/freenas/os-base/amd64/tank/
home/jkh/checkout/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: VIA Nano processor L2200@1600MHz (1615.82-MHz K8-class CPU)
Origin = "CentaurHauls" Id = 0x6f2 Family = 0x6 Model = 0xf Stepping = 2
Features=0xafc9fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C
MOV,PAT,CLFLUSH,ACPI,MMX,FXSR,SSE,SSE2,SS,TM,PBE>
Features2=0x63a9<SSE3,MON,VMX,EST,TM2,SSSE3,CX16,xTPR>
AMD Features=0x2a100800<SYSCALL,NX,FFXSR,RDTSCP,LM>
AMD Features2=0x1<LAHF>
VIA Padlock Features=0x70dcc<RNG,AES,AES-CTR,SHA1,SHA256>
TSC: P-state invariant
real memory = 4294967296 (4096 MB)
avail memory = 2949750784 (2813 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <CN896 AWRDACPI>
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 0.3> irqs 0-23 on motherboard
ioapic1 <Version 0.3> irqs 24-47 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: <AES-CBC,SHA1,SHA256> on motherboard
acpi0: <CN896 AWRDACPI> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, b7de0000 (3) failed
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x73 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
acpi_button0: <Power Button> on acpi0
acpi_button1: <Sleep Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
agp0: <VIA 3364 (P4M900) host to PCI bridge> on hostb0
agp0: aperture size is 128M
pcib1: <PCI-PCI bridge> at device 1.0 on pci0
pci1: <PCI bus> on pcib1
vgapci0: <VGA-compatible display> mem 0xd0000000-0xd7ffffff,0xdd000000-0xddfffff
f irq 16 at device 0.0 on pci1
pcib2: <ACPI PCI-PCI bridge> irq 27 at device 2.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pci2: <mass storage, SCSI> at device 0.0 (no driver attached)
pcib3: <ACPI PCI-PCI bridge> irq 31 at device 3.0 on pci0
pci3: <ACPI PCI bus> on pcib3
vge0: <VIA Networking Velocity Gigabit Ethernet> port 0xcc00-0xccff mem 0xdfdff0
00-0xdfdff0ff irq 28 at device 0.0 on pci3
vge0: Using 1 MSI message
miibus0: <MII bus> on vge0
ip1000phy0: <IP1001 10/100/1000 media interface> PHY 1 on miibus0
ip1000phy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000base
T-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
vge0: Ethernet address: 00:40:63:f9:f8:45
atapci0: <VIA 8237 SATA300 controller> port 0xfc00-0xfc07,0xf800-0xf803,0xf400-0
xf407,0xf000-0xf003,0xec00-0xec0f,0xe800-0xe8ff irq 21 at device 15.0 on pci0
ata2: <ATA channel> at channel 0 on atapci0
ata3: <ATA channel> at channel 1 on atapci0
atapci1: <VIA 8237 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,
0xe400-0xe40f at device 15.1 on pci0
ata0: <ATA channel> at channel 0 on atapci1
ata1: <ATA channel> at channel 1 on atapci1
uhci0: <VIA 83C572 USB controller> port 0xe000-0xe01f irq 20 at device 16.0 on p
ci0
usbus0 on uhci0
uhci1: <VIA 83C572 USB controller> port 0xdc00-0xdc1f irq 22 at device 16.1 on p
ci0
usbus1 on uhci1
uhci2: <VIA 83C572 USB controller> port 0xd800-0xd81f irq 21 at device 16.2 on p
ci0
usbus2 on uhci2
uhci3: <VIA 83C572 USB controller> port 0xd400-0xd41f irq 23 at device 16.3 on p
ci0
usbus3 on uhci3
ehci0: <VIA VT6202 USB 2.0 controller> mem 0xdffff000-0xdffff0ff irq 21 at devic
e 16.4 on pci0
usbus4: EHCI version 1.0
usbus4 on ehci0
isab0: <PCI-ISA bridge> at device 17.0 on pci0
isa0: <ISA bus> on isab0
pcib4: <ACPI PCI-PCI bridge> at device 19.1 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI Host-PCI bridge> on acpi0
pcib5: could not evaluate _ADR - AE_NOT_FOUND
pci128: <ACPI PCI bus> on pcib5
pci128: <multimedia, HDA> at device 1.0 (no driver attached)
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
orm0: <ISA Option ROM> at iomem 0xc0000-0xcffff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
ppc0: cannot reserve I/O port range
wbwd0: DevID 0x3c DevRev 0x02, will not attach, please report this.
est0: <Enhanced SpeedStep Frequency Control> on cpu0
est: CPU supports Enhanced Speedstep, but is not recognized.
est: cpu_vendor CentaurHauls, msr 80d101a0800101a
device_attach: est0 attach returned 6
p4tcc0: <CPU Frequency Thermal Control> on cpu0
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, loggi
ng disabled
Load Average 0.12, 0.11, 0.09
FreeNAS® © 2013 iXsystems, Inc.
Clear
ReCSS
Console
DOM
Object
Close
EXPERIMENTAL: dojox.timing -- APIs subject to change without notice.
EXPERIMENTAL: dojox.layout.ResizeHandle -- APIs subject to change without notice.
EXPERIMENTAL: dojox.grid.EnhancedGrid -- APIs subject to change without notice.
EXPERIMENTAL: dojox.grid.TreeGrid -- APIs subject to change without notice.
Shell
DUMMYNET 0xfffffe00025a11c0 with IPv6 initialized (100409)
load_dn_sched dn_sched QFQ loaded
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen3.1: <VIA> at usbus3
uhub0: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen2.1: <VIA> at usbus2
uhub1: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen1.1: <VIA> at usbus1
uhub2: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen0.1: <VIA> at usbus0
uhub3: <VIA UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen4.1: <VIA> at usbus4
uhub4: <VIA EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
ada0 at ata3 bus 0 scbus1 target 0 lun 0
ada0: <INTEL SSDSA2CT040G3 4PC10362> ATA-8 SATA 2.x device
Clear
ReCSS
Console
DOM
Object
Close
Shell
Clear
ReCSS
Console
DOM
Object
Close
Shell
Clear
ReCSS
Console
DOM
Object
Close
Shell
ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada0: 38166MB (78165360 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad6
Timecounter "TSC" frequency 1615824248 Hz quality 1000
cd0 at ata2 bus 0 scbus0 target 0 lun 0
cd0: <Slimtype DVD A DS8A3S HP52> Removable CD-ROM SCSI-0 device
cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray c
losed
Root mount waiting for: usbus4 usbus3 usbus2 usbus1 usbus0
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub4: 8 ports with 8 removable, self powered
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
