dogmata
- Mar 5, 2012
Hi, first post so please be gentle.
I'm not sure if this is a bug or my syntax, my example is below.
I press mount, and the OK but the options are not available in the config when editing the plugin, and when you go back into the "mount points" option it is blank.
I sum how have managed to get a location within "/usr/pbi/transmission-amd6/etc/transmission/home/Downloads" and "/usr/pbi/transmission-amd6/etc/transmission/home/" mounted but can find no way to unmounted them.
Any help or guidance would be appreciated.
Cheers.
Cheers.
