7TB Volume reporting 99% full but only reporting 3.2TB's of data
Travis Mara
After running the latest update on my system and also enabling File History on my two Windows 8.1 machines, my FreeNAS is reporting that my 7TB volume is full and has disabled my plugins. However when I total up the amount on space being used by each Folder in the Storage tab, it totals up to about 3.2 TB's, which should be correct. Any ideas on this one?
Bidule0hm
Server Electronics Sorcerer
Do you have any snapshots?
Travis Mara
I checked and there was nothing there. It just seems odd that its almost exactly double of the actual data on there.
Debug file please....
SweetAndLow
Sweet'NASty
Looks like you are using more than just 3.2TB. But I can't quite figure out what is using up the space. I have a feeling it is snapshots, quotas or reservation because df is showing strange output also and df doesn't know about those things.
Media         7.25T  6.97T   289G         -    27%    96%  1.00x  ONLINE  /mnt
Travis Mara
If you check that screenshot I posted as well, all of the folders only add up to the 3.2 TB or so. Is there anything I can try in a shell to clear out any snapshots that arent showing up in the GUI?
