BDMcGrew
- Sep 22, 2015
I'm working on my first FreeNAS build with 9.3-REL using a 45 Drives (Backblaze) POD 4.0. I've read cyberjock's PP presentation with all the best practices and I've trolled the forums for a couple weeks before posting so I think I have a good idea of what I should and shouldn't do...
The current system configuration is:
SuperMicro X9 motherboard
Xeon X3470 CPU
32GB DDR3-1333R ECC RAM (4x8GB)
2x HighPoint Rocket 750 Controllers.
500GB WD Boot Drive on Mobo SATA3 Port
Initially I will start with 4x4TB WD RED or 4x6TB WD Ae (see below) and add 4x at a time as needed.
HBA:
My first question is regarding the Rocket 750 card. I've read many posts that say HighPoint cards are generally bad and I've heeded that warning, however, I have not seen much about the R750 cards and what I have seen seems to be a year or so old. HighPoint as well as 45Drive seem to have recent drivers for FreeBSD/FreeNAS and outside the FreeNAS community it seems these are somewhat of an acceptable solution. I've used the card in previous Linux installations with good results but never with FreeBSD and I won't defend the card since I have no real partiality as to whether or not I use it save for spending a few bucks on a new card.
The R750 appears to be JBOD and exposes all the real drives to the system and as far as I can tell does not write any of its own configuration to the drives. However, the reading I've done leads me to believe they've just taken the port multipliers out of the case and put it on the card (which is of course, bad). So what is the consensus? Is anyone actually using these cards and do they work? If it might be a promising solution then I'm willing to spend the time on a 4 to 8 week burn-in, as I'm in no hurry and have plenty of time (~6 months or so). If the card is known to be a waste of time then I'll scrap it and not waste mine or your time screwing with it.
IBM ServRAID M1015's are all over eBay as all the posts here suggest. Easy enough right! These cards have two mini-sas connectors on them. The system is currently wired for 45 drives where every four physical ports go into a mini-sas connector that attaches to the card. Shouldn't I just be able to move a couple of the mini-sas connectors from the R750 cards onto a ServRAID card and still run 8 drives on each card? Or am I mistaken?
HDD's
I will use enterprise drives without argument. My debate is between WD Red 4TB drives and WD (Yellow) Ae 6TB drives. I would prefer of course to use the bigger drives if I can do so safely, even though they're only 5,900RPM and add a couple of SSD for ZIL and L2ARC (which I will do anyway).
For my ZIL and L2ARC I'm considering a StarTech PEXMSATA3422 with 2x Samsung 120GB mSATA SSD. These cards just work with Linux but I don't see a whole lot about them for FreeBSD/FreeNAS. If this is not a good choice, when what would be the recommendation? I would much prefer to use 2x mSATA on a PCIe card vs. a 2.5" SSD in an adapter in a drive bay.
Again, I will do a 4 to 8 week burn-in once I have acceptable hardware!
Network:
The mobo has 2x Intel cards plus an IPMI port. Is this a good solution for long term sustainability or should I just get a i340-T2 and be done with it???
Thanks in advance for and advice and comments!
-brian
Xeon X3470 CPU
HBA:
HDD's
Network:
-brian
