4 hd enough?
ela002
I am thinking to build freenas for first time. I don't care to have multiple parity as I will backup to more locations. How I can get mot usable space from 4 HDs?
William Grzybowski
Use raidz1, you will lose 1 HDD for parity.
But if you're looking for optimal performance go with 5, it is the optimal number for raidz ((2^n + 1)
ela002
Thanks for the reply.
However if I use for example 4x1TB HDs, raidz1 this means I will have 3TB (2.7 TB actually) usable disk space from which 1 can fail and not lose any data ?
Thanks
