4 GB Thecus N7710
haQQo
Merhaba. Thecus n7710 kullanıyorum. RAM miktarı 4 GB'dir. FreeNas'ta minimum ram miktarı 8 GB'dir. Yüklemem mümkün mü? Sadece film arşivleri yapmak için kullanıyorum.
Google translate renders this question as:
Hello. I am using Thecus n7710. The amount of RAM is 4 GB. The minimum ram amount in FreeNas is 8 GB. Is it possible to upload? I only use it to make movie archives.
Minimum means minimum, so no, I wouldn't expect FreeNAS to work and behave properly with half the required minimum amount of RAM. A quick Google search suggests that you should be able to upgrade the RAM, though.
