derWalter
- Dec 5, 2020
Hey guys, I need your advice, if I am at the right place here.
I am an ex-Networking guy, gone for some years now.
(Switched into social work.)
Now I discovered SCALE and I am interested in getting my fingers dirty again,
so I have to create a case I can motivate myself with :)
I am thinking of starting little, with setting up a NextCloud and data grave for my family.
A small setup like Raid1 10TB, on entry level ECC capable hardware, plus external drives for backup.
So what I need to know, if I got the possibilities with SCALE correctly:
Will it be possible to have 3 identical nodes at three different locations,
all being active, so ppl could use NextCloud locally per LAN and also access any
of the nodes via Internet/VPN.
The data should always be in sync between all three nodes, including identical snapshots,
and so forth.
I am rly interested to realize this with SCALE and dive into the required topics again,
but I don't know if SCALE is meant to build such systems, if its possible with the
available licensing or if I would throw away my time trying to realize this.
Maybe its important to note that I'm not in a rush with this project.
Thanks for your time reading my questions
Walter
and so forth.
Walter
