3 drives best setup -phantom?
LaurenceL
Hi. I have 3 drives connected to sata ports and my boot up ssd connected to sas port.
when I go to create a pool I only see options stripe,mirror and raids not raidz2, is this correct?
I may have another drive coming but not sure where I’m going to plug it in yet. I have seen some discussion about creating a phantom drive until it arrives. How does that work?
if I decide to stick with 3 drives what is my best option? 2 drives striped and use the third to create a back up everyday?
my System is a prehistoric dell precision 690 but it was cheap and enough to get me started.
this leads on to another question about booting up, my boot up ssd is plugged into a sas port so I have to press f12 and select it as the boot disk every time I turn it on. What are my options? May be a pci-e card with more sata connectors?
Tia
3 drives
I had understood that the minimum drive count for a RAIDZ2 VDEV was 4.
If you want 1 data disk and 2 "parity" disks, use a 3-way mirror.
That's correct. For any form of parity RAID, it's a minimum of two disks plus parity (so three for RAIDZ1, four for RAIDZ2, five for RAIDZ3).
I would not recommend doing that with data you care about.
LaurenceL
Ok so I need to get the fourth disk. I will then have to plug them all into the sas ports on the mobo. When I boot up I have the option of going into the sas controller. Can I go into this controller and turn off any raid options it may give me as I want Freenas to look after that?
If it's just a SAS controller with no RAID chip involved, fine, but read the above thread in any case.
LaurenceL
It can do raid 0 or 1
LaurenceL
It says LSI logic config utility for dell sas 5 v6
I see options to change boot up in the menu; disabled, boot os, boot bios, boot os and bios.
I want the controller to see the hard drives but not raid them. Will try in the morning
