Looking for suggestions on the best way to setup freenas on the following Dell R510 server.
This setup will be a dedicated SAN/NAS for two other R510 servers running esxi 5.5.
The two host servers, are running
2 x 2.66 Hex Core
32GiB Ram
Dell H700 SAS Controller
1 x Quad Port NIC
2 x On Board Broadcom NICs
This is the Dell R510 12 bay server, to run FreeNas
1 x 2.4GHz Quad Core
12GiB Ram
Dell H700 SAS RAID Controller with 512MiB and battery backup, I have a 1GiB card as well.
10 x 600GiB SAS 15k drives
1 x HP NC364T PCIe 4Pt Gigabit Server Adapter
2 x On board Network Broadcom NetXtreme II BCM5716
I will be installing FreeNas onto a 8GiB SanDisk Cruzer Glide
I'm not sure if I should use the Built In Dell RAID controller to create a RAID or just set all the drives as JBOD and let FreeNas build the RAID.
Since I have both a 1Gib and 512Mib H700 board, would adding a mirrored SSD to the 1GiB board benefit my performance?
I have a single Quad port NIC I plan on using for iSCSI / NFS / vMotion on all 3 servers. My Plan at first is to use a single 48 port switch, vlan those connections off. But will move to a dedicated Switch for those connections.
So...with this info...what suggestions / comments can be offered to get the best performance and usable drive capacity?
Thanks
2 x 2.66 Hex Core
32GiB Ram
1 x Quad Port NIC
12GiB Ram
Thanks
