I'm about to buy a nicely priced secondhand HP MicroServer N54L, install FreeNAS on it and install 5x 3TB HDD's (in RAIDZ) to act as a mediaserver. I want to run FreeNAS off a 16GB SanDisk Cruzer Ultra fit.
The server will do automatic usenet downloads using SABnzbd and a habit I always followed was using separate hard drives for downloading and extracting to keep the load on the drives down as much as possible (no concurrent read and write on the drive), also this allows the drives to idle and spin down more often.
So in order to realize this I want to add 2x 32GB SanDisk Cruzer Ultra fit thumb drives in RAID0 as download volume. I want to use 2x 32GB instead of 1x 64GB to enhance the write speed (because it will double the write capacity with 2 USB drives and hopefully 2 USB 2.0 ports will increase the USB 2.0 bandwidth bottleneck a little).
I expect that the server will download around 25GB a week to the USB drives (and repair and then extract the data to the RAIDZ hard drives).
I have a few questions about this setup:
- Is this still useful in a FreeNAS setup with RAIDZ? I'm mainly interested in prolonging hard drive lifetime.
- Flash memory will wear out. Conservative numbers show that flash memory can handle about 10.000 write cycles. If that's true then 64GB storage * 10.000 cycles / 25GB weekly data writes / 52 weeks per year = 461 years before my USB drives will wear out?
- Any other thoughts on this setup (in general)?
