gbysec
- Oct 3, 2022
Hi !
I'm fairly new in the community, I've built my own NAS last summer and went straight away with TrueNAS SCALE, so far, extremely happy to use k3s and Truecharts !
The only big problem I've got, to be honest, is the upgrade system. I don't know how many times this has happened already, but probably 4 or 5 times, my whole k3s gets corrupted.
Orphaned pods, completely lost configurations (volume mounts mostly)... it's getting a bit annoying, and there seems to be no "simple" way of dumping all my app configurations to a backup at least, in case I need to redeploy all of them everytime.
Either a forced reboot (because of middlewared's memory leak, that was fixed a version or two ago I think), or an upgrade, will always corrupt the cluster.
It's also the openebs-zfs-controller-0 being completely broken sometimes, I have no clue what to do sometimes, apart from wiping everything away, which includes Plex, Sonarr, Radarr, Qbittorrent, Flood, Jackett, a Valheim server, my Homeassistant instance... you see where I'm going.
Sometimes it was also
Another issue I've experienced is the slow storage explosion because of snapshots
www.truenas.com
Jun 05 23:07:04 truenas k3s[390079]: E0605 23:07:04.934764 390079 kubelet.go:1431] "Failed to start ContainerManager" err="invalid kernel flag: vm/overcommit_memory, expected value: 1, actual value: 0"Sometimes it was also
kubernetes.io/csi: attacher.MountDevice failed to create newCsiDriverClient: driver name zfs.csi.openebs.io not found in the list of registered CSI driversAnother issue I've experienced is the slow storage explosion because of snapshots
SOLVED - [SCALE] Mass cleanup/removal of ix-applications snapshots solution required
As I've explained in another post/thread here, there is an issue with snapshots being created for ix-applications dataset and its child datasets. I mean in under a year with moderate to light use, my TrueNAS Scale server has over 47 thousand snapshots created. Yeah, you read that right - it's...
