Johnny5
- Dec 27, 2016
Background:
As someone that works in the tech industry, my home hardware is completely out of date. Our home "server/htpc" is running on hardware whose newest component is over 5 years old. It runs Kodi, serves files via Samba, runs rTorrent/CouchPotato/SickBeard, along with a few useful one-off scripts. It has ~ 2TB of storage space, which means I regularly have to go through and delete media. There is no redundancy, no backups, nothing. If it gets turned off, I say a quick prayer before turning it back on, and try my best to ignore the warnings Debian spews at boot. It's time to stop the madness.
Build Reasoning:
My wife and I bought a house last year, and now that our funds have replenished a bit, it's time to upgrade some of our broke-college-student-budget hardware. First up is a NAS, so we can kill off the ticking time bomb that is our current "server". Ideally, I want a single FreeNAS box that can do a few things:
Hardware:
Initially, I was going to go with a more expensive board like the X11SSH-CTF, so I could buy a new case/PSU, more drives, and add another vdev to the pool. I also looked at the X10SRH-CLN4F. The X10 would give me the same ability to add another vdev, as well as a more powerful e5 processor. However, I don't think I'll utilize 20TB of space before it's cheaper just to replace all the drives or build a new system. I also *think* that the E3-1240 v5 will be enough processor for my use case. Scaling back a bit knocked a few hundred off the price, which I'd rather not pay if it's just going to be wasted.
I do plan on splitting up my HDD purchase, buying half WD Reds and half whatever NAS drive is reasonably priced, to avoid all the drives failing around the same time. None of the prices above have been shopped around, it's just a ballpark using NewEgg and Amazon.
Does my build look alright? I'm new to FreeNAS, but have spent quite a few hours going over the various guides, looking at hardware features, etc. Planning on putting all the disks in one raidz2, which should give me 20TB. Will this build fully support all the new virtualization hotness in FreeNAS 10? Do I need a bigger PSU? I know I'll probably have to pick up some extra fans, any recommendations for that case? All my hardware choices are very provisional, I'll gladly take any and all advice. Thanks.
Build Reasoning:
- Run FreeNAS w/ 16TB+
- Serve files for our (currently) 3 computers, including 2 devices at once using Kodi
- Run a torrent client, CouchPotato, and SickBeard
- Act as a DNS server for our home network
- Possibly run ZoneMinder or some other software for security cameras - ZM has fairly heavy CPU usage
- Run a database instance for Kodi
- Run nginx and a small (non-public) site
- Possibly run a VM or two for home automation and personal projects
Hardware:
Drives: 7x WD Red 4TB $980 Motherboard: SuperMicro X11SSM-F $209 Memory: 2x Micron 16GB 2133 DDR4 $200 Processor: Intel Xeon E3-1240 v5 $290 Case: Fractal Design Node 804 $100 Power Supply: SeaSonic G-550 $60 Total Cost: $1,839
