oOFishbowlOo
 - Apr 22, 2015
This is annoying me no end and i'm pretty sure it's something simple:
Details are:
So that was unfortunate. Failed drive smartctl looks like this:
Ordered a replacement disk (WD Red 1TB), however when I try to run the replacement procedure:
So i'm thinking this is due to the size of the swap partition (reading through the forums). I can't remember what version of FreeNAS I created this pool on (can someone tell me?), but it would have been around 8.x or maybe 9.0, so maybe i've got a 1GB swap on the old drive, and trying to create a 2GB swap on the new? I also had to do some initial partition jiggery-pokery in order to get the 2TB disk to work with the rest of the 1TB drives, but that should have only affected the 2TB disk. When I look at gpart show I don't see the 1TB drives at all, which I take to mean either they have no partition map, or they were initialized with the GUI?
So I guess my 3 questions are:
Details are:
- OS Build: FreeNAS-9.3-STABLE-201504152200 64bit
 - CPU: AMD Athlon II Neo N36L / 1.3 GHz
 - RAM: 8GB Kingston (unsure what model)
 - MB: No idea, something proprietary
 - Array: 4x 1TB WD Caviar Green, 1x 2TB WD Red (RAIDZ2)
hippo# zpool status tank
  pool: tank
 state: DEGRADED
    corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 284K in 3h30m with 1 errors on Tue Apr 21 22:38:35 2015
    tank                                            DEGRADED     0     0     1
     raidz1-0                                      DEGRADED     0     0     2
       ada0                                        ONLINE       0     0     0
       3179613386919869858                         OFFLINE      1     0    54  was /dev/ada1
       ada2                                        ONLINE       0     0     0
       ada3                                        ONLINE       0     0     0
       gptid/f574d7c0-e77d-11e4-8fbc-3c4a9277b6d7  ONLINE       0     0     0
Model Family:     Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model:     WDC WD10EZRX-00A8LB0
Serial Number:    WD-WCC1U3332544
LU WWN Device Id: 5 0014ee 2b3395687
Firmware Version: 01.01A01
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Apr 22 10:52:28 2015 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (12540) seconds.
capabilities:             (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:     (   2) minutes.
Extended self-test routine
recommended polling time:     ( 144) minutes.
Conveyance self-test routine
recommended polling time:     (   5) minutes.
SCT capabilities:           (0x30b5)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   198   197   051    Pre-fail  Always       -       56741
  3 Spin_Up_Time            0x0027   135   132   021    Pre-fail  Always       -       4241
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       35
  5 Reallocated_Sector_Ct   0x0033   186   186   140    Pre-fail  Always       -       597
  7 Seek_Error_Rate         0x002e   200   139   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   082   082   000    Old_age   Always       -       13807
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       35
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       51
193 Load_Cycle_Count        0x0032   106   106   000    Old_age   Always       -       283902
194 Temperature_Celsius     0x0022   116   109   000    Old_age   Always       -       27
196 Reallocated_Event_Count 0x0032   075   075   000    Old_age   Always       -       125
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       62
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       69
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       58
SMART Error Log Version: 1
No Errors Logged
- zpool offline tank ada1
 - *power down chassis. replace disk. power on chassis*
 - In the GUI, Go Storage -> Volumes -> Volume Status -> hit "Replace" on the disk formerly known as ada1
- Any suggestions about what might be the issue? (i'll get the smartctl output for the new drive tonight if that'll help)
 - Is there any way to work out what version of FreeNAS the pool was created under?
 - Is there any way to look at the current partition map for the failed device if it's not showing up in gpart?
