SOLVED 12.0U1 Sharing Issue?
jlpellet
When I updated to 12.0U1 my old devices, replying on SMB1 fail to properly authenticate. Reverting to 12.0 & SMB works. Verified on 2 different servers. Since I've not found the U1 release notes, does anyone have ideas? I verified SMB service SMB1 is checked. Thanks in advance for any suggestions.
jlpellet
I think I've properly send a debud file as a new conversation. I did not see anythin in the release notes that seemed likely. THanks for any help.
anodos
Sambassador
Bug is in processing certain SMB1 requests and unfortunately slipped through testing. Fix is merged into 12.0-stable, and so will be in next release.
jtiller90
Im having same problem all my old WDTVLive boxes cant connect they were working great on version 12.0
so im confused as well how do i revert back to 12.0 or will there be another update soon to fix this ?
anodos
Sambassador
If you go to System->Boot, you can select the boot environment you for 12.0-RELEASE and click the button to activate it, then reboot.
