After updating to 12.0-BETA most of my jails do not start anymore.
As a first naive approach I first updated one of the jails from the GUI and then tried to upgrade it without success.
Using the CLI command I learned that I first had to fetch the new 12.1 release. Actually 12.1 should work because TrueNAS 12.0-BETA should work with all 12.x releases.
After some minor errors the upgrade procedure ended and starting the jail resulted in an error referring to missing devfs rulesets. However, the GUI under I found out that the number 7 set in the GUI was not listed as a ruleset number anymore. Changing this number to 4 did allow me to start the jails again.
However, I have not understood the concept behind the devfs rulesets. Could anybody give me some insight into these devfs rulesets and perhaps tell me why the numbers have changed.
Using the CLI
iocage upgrade
Jail properties
gives an option to set a devfs ruleset number. With Code:
devfs rule showsets
