11.3 Shell Cut and Paste broken?
It looks like cut (Ctrl-Ins) and paste (Shift-Ins) is broken within the 11.3 Shell. I've tried on Chrome, Firefox, Edge on different Windows 10 PCs and the behaviour is the same for each. Can anyone confirm or debunk before I file a bug report?
Alecmascot
Works fine for me.....
W10 Firefox
Curious. This is what I'm seeing.
Under 11.2, the highlighted text pastes correctly (last line).
Under 11.3, it doesn't for me. What's weird is the way the text is highlighted. It seems to have selected text a couple of lines above.
Having said that, cut and paste seems to work, in a manner of speaking, for the first couple of lines above and then breaks, in this case, from line 3 where the date wraps.
The other thing I noticed is when I maximise the font size in the 11.3 Shell, the text seems to get bunched up.
Under 11.2, line spacing looks fine at the maximum font size. Seems like what I'm observing is some issue with line spacing in 11.3.
All my 11.3 servers are exhibiting the same behaviour. My 11.2 server is fine. It's the same behaviour in any browser I use and from any Windows 10 PC.
@Patrick M. Hausen I'm aware that you have several 11.3 systems. Have you seen the issue above with your system? If you have, I'll submit a ticket for this as well.
Same thing here. I did not notice, because I don't use the shell in the UI. That's what SSH is for ;)
Kind regards,
Patrick
There's already an open ticket for this issue NAS-104469
Still unresolved in 11.3-U2.
