11.2U5 to 112.U7 not happening
marcevan
Tried to update this AM and while System/Update shows me the way, "Update... Starting Job" stuck at 0% for 30 minutes still.
D
dlavigne
Guest
Did the update complete? If not, anything in /var/log/messages around the time it failed?
marcevan
No it never downloaded at all. Was stuck getting the u7 and stayed that way for hours. So abandoned.
D
dlavigne
Guest
Anything in the logs? You can ping an Internet address? There is plenty of space left on the boot device?
marcevan
I can ping www.espn.com with < 1.1 ms
When I try system/update and say install pending update it launches a modal window showing 0% retrieving update manifest
Fredda
Try freenas-update -v check from the console, this might help to see what's going on.
marcevan
I manually rebooted and then the update is now working. Odd. But now it just finished, rebooted and I'm U7
