trinxie
- Feb 7, 2013
Upgraded from 11.1u6 to 11.2, so far all ok
The guide differs between 11.1u6 and 11.2 for section "Replacing an Encrypted Disk"
11.1u6:
8.1.10.1. Replacing an Encrypted Drive
If the ZFS pool is encrypted, additional steps are needed when replacing a failed drive.
First, make sure that a passphrase has been set using the instructions in Encryption before attempting to replace the failed drive. Then, follow the steps 1 and 2 as described above. During step 3, a prompt will appear to input and confirm the passphrase for the pool. Enter this information then click the Replace Disk button. Wait until the resilvering is complete.
Next, restore the encryption keys to the pool. If the following additional steps are not performed before the next reboot, access to the pool might be permanently lost.
11.2:
9.4.1.1. Replacing an Encrypted Disk
First, make sure that a passphrase has been set using the instructions in Managing Encrypted Pools before attempting to replace the failed drive. Then, follow steps 1 and 2 as described above. During step 3, there will be a prompt to enter and confirm the passphrase for the pool. Enter this information, then click REPLACE DISK. Wait until resilvering is complete.
Next, restore the encryption keys to the pool. If this additional step is not performed before the next reboot, access to the pool might be permanently lost.
Is this correct for 11.2?
11.1u6:
- Highlight the pool that contains the recently replaced disk and click the Encryption Re-key button in the GUI. Entry of the root password will be required.
- Highlight the pool that contains the disk you just replaced and click Create Passphrase and enter the new passphrase. The old passphrase can be reused if desired.
- Highlight the pool that contains the recently replaced disk and click the Download Key button to save the new encryption key. Since the old key will no longer function, any old keys can be safely discarded.
- Highlight the pool that contains the disk that was just replaced and click the Add Recovery Key button to save the new recovery key. The old recovery key will no longer function, so it can be safely discarded.
11.2:
- Highlight the pool that contains the recently replaced disk and click Add Recovery Key to save the new recovery key. The old recovery key will no longer function, so it can be safely discarded.
