11.2-BETA2 Plugin Management problems
babaz83
Hi All,
unfortunately I discover another strange behaviour that doesn't let me configure any plugin.
Unfortunately when I click on management of a certain plugin it opens another login page saying that the token is expired is doing that in loop there is no way to configure the plugin and use it.
Please help.
Thank you.
Alecmascot
Roll back to non-Beta software : 11.1-U5
Alecmascot
Then you're st***ed.....
I would still attempt a roll-back. The ZFS upgrade will probably not matter.
"Anyway 11.2 is recommended for virtualization solutions on the website ..."
It's a BETA......It has all king of bugs.....It only been made available for testing.....
babaz83
I dunno why they put it on the website and recommend it for virtualization and plugins if it is not ready. What is the best way to downgrade without loosing the settings?
Neither do I. And iX hasn't chosen to answer that question, despite being asked several times.
The pool has been upgraded with the 11.2 so I cannot rollback to 11.1 .
Calling @Ericloewe...
Alecmascot
Use the Boot Environment Setting to select the prior software, then reboot.
babaz83
Hi Guys,
just to update you.
I manage only to do a fresh install of the non beta version and reconfigured everything.
I won't touch it anymore ;)
Alecmascot
Glad it's sorted.
