11.2 Beta1 - getswapspace failure
Rickinfl
Since upgrading to Beta I've been getting these.
freenas.home.lan kernel log messages:
> swap_pager_getswapspace(32): failed
> swap_pager_getswapspace(16): failed
> swap_pager_getswapspace(24): failed
Stux
Have you got any swap space in top?
Rickinfl
This hasn't happened since upgrading to Beta. Explain Top please I'm still new to Freenas.
Rickinfl
Never had this issue before the upgrade. Not sure if I need to create a Ticket or not. Dru?
Rickinfl
Something strange is going on I keep getting this error and the report is getting longer and longer. I'm thinking I'll wait until next release to see if it fixes the issue.
Rickinfl
I've been searching this issue and keep finding people talking about previous versions and it was a Memory Leak bug. Not sure if that's this issue or not or in this version.
shad0wca7
I’m having this issue too now. Just received an email with a ton of log spam of this. Never had an issue before the beta.
ByteNick
freenas.local kernel log messages:
In various 11.2 beta, various nightlies.
jbrown705
I too am having this issue. I’m on beta 3. I thought it may have been because I only had 8gb ram, but I upgraded to 32 and it still going on. I also noticed that when I look at the graphs in the ui it looks like just about all the memory was used until I open the ui. This same thing occurred when I had 8gb and still does now with 32. Same thing shows with cpu usage. Anyone else have same symptoms or suggestions on fix?
ByteNick
I still have it.
No fix that I know of.
IronRobi
Having the same issue here on Beta 3 and noticing the same thing on the graphs and reports. I've got 128gb of ram. About to upgrade to RC1 to see if it solves it
jbrown705
I’m on RC1 and still have the issue unfortunately.
mrhanman
I have the same issue. Never had this problem with 11.1.
jbrown705
Anyone still monitoring this? I am still having issues with this. I am actually running out of swap and it's causing things to stop working. It seems to be related to VM's as being a larger culprit, but not entirely at fault. There any wizards out there willing to help us?
Rickinfl
Did anyone put a ticket in again? They might think it's fixed and it's not.
jbrown705
I am not sure how to, but I can if someone give me a little direction. Is it done thru the UI?
Also, just so I understand. If I have 3 8 TB drives, shouldn't I have 6TB of swap mem space? I only show 2 total.
Rickinfl
