11.1U5 to 11.2RC1 - lots of weird alerts?
Dariusz1989
Hey
Not much of a freenass geek been using it for a year and didnt have any issues but I updated today to 11.2RC1 and I got there errors :
system.ram Chart
ram in use = 90.3%
system RAM usage Alarm
ram Family
WARNING Severity
Mon Nov 5 12:56:54 GMT 2018 Time
system.ram Chart
ram in use = 93.4%
ram Family
WARNING Severity
Mon Nov 5 13:17:08 GMT 2018 Time
ipv4.tcphandshake Chart
ipv4 tcphandshake last collected secs = 00:00:13 ago
number of seconds since the last successful data collection Alarm
tcp Family
WARNING Severity
Mon Nov 5 13:30:12 GMT 2018 Time
ipv4.udperrors Chart
ipv4 udperrors last collected secs = 00:00:13 ago
udp Family
WARNING Severity
Mon Nov 5 13:30:20 GMT 2018 Time
ipv4 tcphandshake last collected secs (was warning for 16 seconds)
tcp Family
Recovered from WARNING Severity
Mon Nov 5 13:35:24 GMT 2018
(was warning for 16 seconds) Time
ipv4 udperrors last collected secs (was warning for 16 seconds)
udp Family
Mon Nov 5 13:35:29 GMT 2018
system.swapio Chart
30min ram swapped out = 768.2% of RAM
the amount of memory swapped in the last 30 minutes, as a percentage of the system RAM Alarm
swap Family
CRITICAL Severity
Mon Nov 5 13:44:34 GMT 2018 Time
system.swapio Chart
30min ram swapped out = 27.9% of RAM
swap Family
WARNING Severity
Mon Nov 5 15:06:33 GMT 2018 Time
system.swapio Chart
30min ram swapped out = 38.5% of RAM
swap Family
Escalated to CRITICAL Severity
Mon Nov 5 15:08:33 GMT 2018
(was warning for 2 minutes) Time
They all sound dramatic! What do I do with it all ?!
Chris Moore
Chris Moore
The Netdata service is creating those emails. It doesn't work properly in 11.2. I don't know if anyone filed a bug, but I think they should have. It has been discussed on the forum before.
Dariusz1989
Interesting, so they are nothing I should "panic" about I take? Looks like they are set to panic when stuff runs at 90% - well in ram case, not sure what to think of teh tcp/udp ones and system.swapio... hmm
Chris Moore
I can't say definitively, but I think it is just that the alert levels are not where they should be considering the way that FreeNAS works. The last person that reported this just turned it off so they stopped getting emails. If you would do some investigation and report back, it might help fix the problem in future.
jgreco
Resident Grinch
It is a name not just a collection of letters.
<mod hat>
That's not really that helpful and could be taken badly. Alternative suggestion:
"Please note, the name is FreeNAS, which roughly means Free Network Attached Storage, or possibly FreeBSD-based Network Attached Storage, depending on how you roll."
omcn7
I was getting some of these messages. I did a google search and found this thread. I figured I would add my recent alerts here in case it would help someone..
system.ram Chart
ram in use (was warning for 10 seconds)
ram Family
Sun Feb 17 18:02:42 EST 2019
(was warning for 10 seconds) Time
udp Family
WARNING Severity
Sun Feb 17 15:31:01 EST 2019 Time
ipv4 udperrors last collected secs = 00:01:02 ago
udp Family
Sun Feb 17 01:27:58 EST 2019
(was warning for 50 seconds) Time
It might be worth mentioning that the udp and tcp was after starting a scp session with some fairly large files in them. If it happens again I will take a closer look at the tcp and udp issues. As for the ram alert. I set those to silent cause I know ZFS uses a lot of ram and netdata is just not used to that being normal. For others you can find alerts here
 /usr/local/etc/netdata/health.d
The footer of the netdata emails will show you what created the alert and you can edit the .conf file to silence them *if* you are sure that the issue is "normal" for FreeNAS.
Hopefully this helps and isn't just a dup of another thread. :cool:
