TurboStore
- Jan 1, 2021
I am having trouble reaching the full 10 Gigabit of transfer throughput.
The drives on the server would be easily able to do that.
About the Server:
OS: FreeNAS 11.3
Network: Intel x550-T2 card
Storage: 4x NVMe (PCIe 3.0) SSDs in RaidZ1
Pool write test:
Results in 1.9702 Gbytes per second!
Pool read test:
Results in 6.924 Gbytes per second!
That should proof that the server is more than capable of saturating a 10 Gbit connection.
My networking equipment:
The FreeNAS and my computer both have official Intel x550-T2 Ethernet cards and are directly connected via a Cat6a cable.
I enabled Jumbo Packets of 9014 Bytes both systems.
On my computer I disabled "Interrupt Moderation" which resulted in a big performance boost.
I tried the config from the 45 drives article:
www.45drives.com
On my system I set the Receive Buffers to 4096 and Transmit Buffers to 16384
On FreeNAS
These tunables on the FreeNAS made no difference.
Current performance:
SMB ( CIFS )
iSCSI is similar.
FTP ( plain, unencrypted )
Any help on how to configure FreeNAS to reach 10 gigabit is appreciated!
About the Server:
OS: FreeNAS 11.3
Pool write test:
root@********[~]# dd if=/dev/zero of=/mnt/****/************/test.file bs=4096k count=1000 1000+0 records in 1000+0 records out 4194304000 bytes transferred in 2.128823 secs (1970245185 bytes/sec)
Pool read test:
root@********[~]# dd if=/mnt/****/************/test.file of=/dev/zero bs=4096k count=1000 1000+0 records in 1000+0 records out 4194304000 bytes transferred in 0.605741 secs (6924250990 bytes/sec)
How to Tune a NAS for Direct-from-Server Editing of 5K Video
Typically, if one sets up a 10GbE network, and connects a Storinator running NAS or Server OS to a fast workstation, one will see out-of-the-box transf
On FreeNAS
kern.ipc.maxsockbuf=16777216 net.inet.ip.intr_queue_maxlen=2048 net.inet.tcp.recvbuf_inc=524288 net.inet.tcp.recvbuf_max=16777216 net.inet.tcp.recvspace=4194304 net.inet.tcp.sendbuf_inc=32768 net.inet.tcp.sendbuf_max=16777216 net.inet.tcp.sendspace=2097152 net.route.netisr_maxqlen=2048
SMB ( CIFS )
- Read: 5.9 to 6 Gbps
- Write: 6.8 Gbps
iSCSI is similar.
- Read: 7.1 Gpbs
- Write: 7 Gbps
