WhatAbotBob
- Mar 19, 2018
I had a RaidZ volume with 4 drives and after detaching the volume I am not able to import the volume. I am getting and error (the following disks failed to attach). I did some looking and I found out that I have 2 keys, and after some more digging I found out 2 of the dives are using one encrypted key and the other 2 are using a different one. I am not sure how I did this! I was unable to find a way to add the volume for all 4 drives with the 2 keys. My question is: Is there a way to add the volume with both keys, if not is there anyway to remove one of the keys?
I am running freenas 11.1 with I5 6600 with 8gb ddr4 ram.
