Hi All,
Thanks in advance for any advice anyone can offer.
I am getting this error repeat every 30 minutes (1 email alert but none since..I assume because its not getting worse).
Sep 25 22:30:33 freenas smartd[2371]: Device: /dev/ada3, 1 Currently unreadable (pending) sectors
I'm running smartctl -t long /dev/ada3. I guess its still running (do the results appear somewhere eventually? :)). Is this something to be concerned about?
smartctl -A /dev/ada3 output below. I've got a really LOW Start_Stop_Count which suggests my drives aren't going to sleep? Not sure if that can be a problem.
Should I be worried about this? :)
[root@freenas] ~# smartctl -A /dev/ada3 smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p10 amd64] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 6 3 Spin_Up_Time 0x0027 185 175 021 Pre-fail Always - 5741 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 20 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8302 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 18 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 6 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1725 194 Temperature_Celsius 0x0022 114 109 000 Old_age Always - 36 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
