zpool remove complains about top level vdevs not being the sector size - but they seem all same sector size?
Stilez
OLDPOOL is a pool I'm gradually dismantling, and in parts is getting down to non-redundancy which is fine (I'm grabbing disks for the current replacement pool). I now need to remove one top level vdev. zpool status -v POOL gives the following disk layout which I've annotated with disk info from smartctl -i /dev/DISK_ID:
ada0 - single disk, ST6000NM0024, SATA, "512 bytes logical, 4096 bytes physical"​
ada1 - single disk, ST6000NM0115, SATA, "512 bytes logical, 4096 bytes physical"​
da4 - single disk, ST8000NM0075, SAS 3, "Logical: 512 bytes, physical: 4096 bytes"​
da15 - single disk, ST8000NM0075, SAS 3, "Logical: 512 bytes, physical: 4096 bytes"​
mirror-2​
da5 - ST6000NM0024, SATA, "512 bytes logical, 4096 bytes physical"​
da14 - ST6000NM0054, SAS 3, "Logical: 512 bytes, physical: 4096 bytes"​
I try zpool remove OLDPOOL da4 but get an unexpected error: "Cannot remove da4: all top-level vdevs must have the same sector size and not be raidz."
But all disk have identical top level sector sizes, and I can't check but I'm guessing so do all top level vdevs do as well? (But if not, no idea how to change this.)
What's up and how can I remove one of my ST8000NM0075's?
Samuel Tai
Your zpool status -v OLDPOOL appears to have been edited. Can you provide the raw output, we can understand the pool topology?
