I'm running the latest Freenas on the 11.2 stable train and installed the Zoneminder plugin.
The GUI looked a bit fishy and when looking at the network traffic did I see that all files loaded from "/cache" fail to load (did load the index page using that url).
The fix was to add the cache path to nginx and create 2 directories:
If I click on a added camera then that page (/index.php?view=watch&mid=3) fail to load another url (/zm/index.php?view=request&request=status&entity=events&id=3&count=20&sort=Id desc) using ajax. This can probably be fixed by adding "/zm" to nginx, I guess.
Bug reporting system seem to be down at the moment but I'll check later to try and report it.
ee /usr/local/etc/nginx/conf.d/zoneminder.conf
location /cache {
alias /var/cache/zoneminder;
sudo service nginx restart
mkdir /var/db/zoneminder/events
mkdir /var/db/zoneminder/images
chown www:www /var/db/zoneminder/events
chown www:www /var/db/zoneminder/images/
