Just purchased the FreeNAS mini xl plus with 10gbe. I'd like to maximize throughput on the 10gbe network supporting a Mac and PC(both have 10gb cards to a 10gb supported switch) to the FreeNAS mini.
Background/Details:
Thanks for your help in advance!
Background/Details:
- Purchased to support a wedding photography business
- Editing on either the Mac or PC system with SSD drives
- Will move Lightroom Catalog and raw images to the FreeNAS mini. There will be times when it will be moved back to the local PC or Mac for additional editing etc.. Each Wedding contains a lightroom catalog and Raw images.
- Approximately 120gb of images for each wedding at a time to be moved
- Depending on the camera used, each raw image between 16 and 100 megabytes to give you an idea of file size. There are also a lot of small files within the lightroom catalog. The catalog is essentially a self-contained database that references the raw images.
