JJT211
- Jul 4, 2014
This is an extension from a previous thread I started but it began as something a bit different and I'd like this to be a reference for anyone else needing help with ZFS replication in the future.
My overall goal is to upgrade my storage from a single 1x4tb to a 4x4tb RAID Z2. All disks are WD Red's
My current 1x4tb drive (diskA) has 1.6TB of data. I want to temporarily copy disk A's data to a 2TB (diskB). After the copy is completed, I'll then take disk A and combine it with 3 new 4TB drives to form a 4x4tb RAID Z2 pool. Afterwards I'd like transfer the data from disk B back to my newly created RAID Z2 pool.
ZFS replication seems like the best option. But im having a bit of trouble with the commands.
From what I understand, is I need to create a snapshot of the dataset diskA I want to copy and use the zfs send command to the disk B. I created the snapshots through the GUI. The snapshot I'd like to send to disk B is "mymedia/movies@movies-0306"
It's last item in list. Here's the zfs list of disk A (mymedia) and disk B (temp2tb) which has been already formatted zfs and has an empty dataset already created. disk B and its dataset are the last 2 items.
So now when i try to zfs send disk A snapshot 'mymedia/movies@movies-0306' to disk B, I keep getting below
So am I supposed to overwrite the dataset on disk B? Thats fine as there's nothing on it, but I also get that broken pipe error as well.
What am I doing wrong?
[root@freenas] /# zfs list -t snapshot NAME USED AVAIL REFER MOUNTPOINT freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501212031@2015-02-20-09:53:36 4.42M - 938M - freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-01-14-03:50:40 934M - 934M - freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-01-22-20:31:05 324M - 936M - freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-02-20-04:01:24 328M - 939M - freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-02-23-04:14:13 272M - 938M - freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818@2015-03-01-03:45:11 273M - 950M - freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201501090144 42K - 7.77M - freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201501212031 45.5K - 7.77M - freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201502162250 50K - 7.78M - freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201502210408 7.78M - 7.79M - freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201502271818 7.78M - 7.80M - mymedia@main-20150306 0 - 244K - mymedia/.warden-template-pluginjail@clean 88K - 719M - mymedia/Jails/.warden-template-pluginjail@clean 7.88M - 719M - mymedia/Jails/.warden-template-standard@clean 88K - 1.55G - mymedia/movies@movies-0306 0 - 1.31T - [root@freenas] /#
[root@freenas] /# zfs list NAME USED AVAIL REFER MOUNTPOINT freenas-boot 3.79G 10.6G 31K none freenas-boot/ROOT 3.75G 10.6G 31K none freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501090144 3.56M 10.6G 935M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501212031 9.80M 10.6G 939M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502162250 4.43M 10.6G 938M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502210408 4.82M 10.6G 950M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818 3.73G 10.6G 930M / freenas-boot/ROOT/default 2.92M 10.6G 934M legacy freenas-boot/grub 31.2M 10.6G 7.80M legacy mymedia 1.65T 1.86T 244K /mnt/mymedia mymedia/.system 5.70M 1.86T 2.61M legacy mymedia/.system/cores 1.10M 1.86T 1.10M legacy mymedia/.system/rrd-5d7cf704701c492ab661d665947c290a 96K 1.86T 96K legacy mymedia/.system/samba4 648K 1.86T 648K legacy mymedia/.system/syslog-5d7cf704701c492ab661d665947c290a 1.27M 1.86T 1.27M legacy mymedia/.warden-template-pluginjail 719M 1.86T 719M /mnt/mymedia/.warden-template-pluginjail mymedia/Jails 30.2G 1.86T 232K /mnt/mymedia/Jails mymedia/Jails/.warden-template-pluginjail 727M 1.86T 719M /mnt/mymedia/Jails/.warden-template-pluginjail mymedia/Jails/.warden-template-standard 1.55G 1.86T 1.55G /mnt/mymedia/Jails/.warden-template-standard mymedia/Jails/couchpotato_1 265M 1.86T 978M /mnt/mymedia/Jails/couchpotato_1 mymedia/Jails/crashplan_1 331M 1.86T 1.02G /mnt/mymedia/Jails/crashplan_1 mymedia/Jails/headphones_1 182M 1.86T 896M /mnt/mymedia/Jails/headphones_1 mymedia/Jails/openvpn 335M 1.86T 1.65G /mnt/mymedia/Jails/openvpn mymedia/Jails/owncloud 468M 1.86T 1.78G /mnt/mymedia/Jails/owncloud mymedia/Jails/plex 22.7G 1.86T 23.4G /mnt/mymedia/Jails/plex mymedia/Jails/sabnzbd_1 167M 1.86T 881M /mnt/mymedia/Jails/sabnzbd_1 mymedia/Jails/sonarr_1 749M 1.86T 1.43G /mnt/mymedia/Jails/sonarr_1 mymedia/Jails/subsonic_1 1.51G 1.86T 2.21G /mnt/mymedia/Jails/subsonic_1 mymedia/Jails/transmission_1 1.36G 1.86T 1.69G /mnt/mymedia/Jails/transmission_1 mymedia/downloads 16.8G 1.86T 16.8G /mnt/mymedia/downloads mymedia/movies 1.31T 1.86T 1.31T /mnt/mymedia/movies mymedia/music 96K 1.86T 96K /mnt/mymedia/music mymedia/openvpn 172K 1.86T 172K /mnt/mymedia/openvpn mymedia/tv 298G 1.86T 298G /mnt/mymedia/tv temp2tb 396K 1.76T 96K /mnt/temp2tb temp2tb/dataset 96K 1.76T 96K /mnt/temp2tb/dataset [root@freenas] /#
[root@freenas] /# zfs send mymedia/movies@movies-0306 | zfs receive temp2tb/dataset cannot receive new filesystem stream: destination 'temp2tb/dataset' exists must specify -F to overwrite it warning: cannot send 'mymedia/movies@movies-0306': Broken pipe [root@freenas] /# zfs send mymedia/movies@movies-0306 | zfs receive temp2tb cannot receive new filesystem stream: destination 'temp2tb' exists must specify -F to overwrite it warning: cannot send 'mymedia/movies@movies-0306': Broken pipe [root@freenas] /# zfs send mymedia/movies@movies-0306 | zfs receive temp2tb/dataset cannot receive new filesystem stream: destination 'temp2tb/dataset' exists must specify -F to overwrite it warning: cannot send 'mymedia/movies@movies-0306': Broken pipe
