Oko
- Nov 30, 2013
During the replication of ZFS data set from a FreeNAS 9.2.1.5 onto TrueOS 10.1.1 box I noticed that ssh has timed out. Soon after I noticed TrueOS server (target) went down. I found server in kernel panic mode apparently complaining about SAS adapter. TrueOS box which panicked has a SAS adapter capable of 24 HDD (I have only 12 HDD attached which was creating some problems due to SAS logic. I had to move HDD from 0:5 bay to 0:23 bay to be recognized). The TrueOS server in question utilizes HBA LSI SAS 9211-8i. HDD are connected to HBA via SAS adapter as otherwise I would not be able to use 12 HDD.
After the reboot I noticed that boot ZFS pools I created
/storage1
and
/storage2
are missing while storage pool /tank is correctly mounted. Note that in reality /tank consist of one 32GB SSD HDD.
The missing ZFS pools consist of 6x3TB (storage1) and 6x2TB(storage2) HDD. I was very concern initially because I have only 12 GB of RAM (I tried adding 12GB more but was not recognized because it is different type). However things seems to be working OK. I replicated successfully data set of 3TB onto /storage1 and I was almost done replicating another data set to the same storage pool.
Can somebody point me how to look for missing ZFS pools? I have in /etc/rc.conf. Was it a wrong thing to try to replicate second data set onto the same ZFS pool?
The only purpose of this server is to hold backup data. So after initial replication the load should be near zero.
Thanks.
/storage1
and
/storage2
zfs_enable="YES"
Thanks.
