Atle-Andr Gundersen
- Jun 10, 2012
Hello, its good to be back :)
I'm having a little annoying problem which I'm trying to resolve, but I need some professional help on this one.
I took my computer appart to do some maintenace, which included dust-removal and adding new thermal paste to the CPU. When I turned it back on everything looked normal, until I saw a flashing yellow light in the right corner.
One of my volumes, which happens to be a ZFS stripe (I know, dumb config) consisting of 2x 3TB WDG drives is unknown.
"WARNING: The volume Media (ZFS) status is UNKNOWN".
Now, I have been doing some research as I've seen there is a lot of topics on this type of issue, but I cannot find anything specific to my issue.
I did a "zpool import" "zpool status" in the concole, and looking at the volume it tells me the following:
pool: Media
state: ONLINE
acton: The pool can be imported using its name or numric identifier.
Media ONLINE and a two lines of numbers and digits I believe to be the HDD ID's which also are online.
So it seems that the volume is ok, but I'm not good enough to understand how to import this volume, if it is possible at all.
Any help is greatfully appricated, as I got these two disks filled up with alot of history which I cannot afford to lose.
EDIT:
System Information
Hostname freenas.local
Build FreeNAS-8.3.0-RELEASE-x64 (r12701M)
Platform Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz
Memory 8176MB
System Time Fri Apr 04 21:40:45 CEST 2014
Uptime 9:40PM up 2:01, 0 users
Load Average 0.12, 0.06, 0.01
Connected through 192.168.0.184
Best Regards
Atle-A.
pool: Media
state: ONLINE
EDIT:
System Information
Memory 8176MB
Best Regards
Atle-A.
