trevorault
- Aug 20, 2012
I've been running FreeNAS for several years and recently had issues accessing the GUI and AFP/NFS shares. I installed 9.1.0 on a brand new USB stick and have errors with my ZFS pool. Do I need to replace drives first (it looks like the 2nd has failed with the 1st one having issues as well) or do something with the existing pool to get it online first? I looked through the files with errors and am OK if I lose them. What are the recommended next steps? I appreciate any help.
[root@freenas] ~# zpool status
pool: Carlos
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: resilvered 6.95G in 0h9m with 25724 errors on Fri Aug 23 07:00:37 2013
NAME STATE READ WRITE CKSUM
Carlos DEGRADED 0 0 34.3K
raidz1-0 DEGRADED 0 0 95.4K
gptid/b2600453-714d-11e1-90bd-00151731e8a6 ONLINE 0 0 186
gptid/b2afe3dd-714d-11e1-90bd-00151731e8a6 FAULTED 47 1.32K 28 too many errors
gptid/b2feb193-714d-11e1-90bd-00151731e8a6 ONLINE 0 0 0
gptid/b34e3de7-714d-11e1-90bd-00151731e8a6 ONLINE 0 0 0
errors: 25725 data errors, use '-v' for a list
