ZFS Fragmentation question
Mr_N
Would it make any difference if I deleted the data I'm going to replace before extending my pool with 2nd vdev or after?
mav@
Addition of new vdev does not move any data to it by itself. So it should not make difference whether you delete anything before the addition or after. New writes on the other hand should matter -- writes done after new vdev added for significant part will go to new vdev and will be written there with minimal fragmentation.
Mr_N
so it isn't an equal striping across vdevs if one is already ~40-50% full?
mav@
ZFS stripes data between vdevs based on their write performance. Old full and probably fragmented vdev will likely be slower then empty new one, so it should receives less new writes.
Mr_N
ahh ok
