Hi all. My FreeNAS 8.0.1b2 install crapped out on me tonight and i have been trying to recover from it since already half a day ago. I tried, i really did but i guess i need some help before it really turns ugly (if everything is not already lost).
Ok, so; I'm running 2*2tb disks in a mirror zfs pool, or well, i used to. All of a sudden samba stopped working while nfs didnt. After a reboot nothing worked, on inspection of the console i found out rather quick that there were no zpools whatsoever. status, import, it wouldnt budge. I made a quick install on a seperate disk and tried to import the mirror or just 1 disk and it wouldn't show up there either.
I'm at a standstill and took both of the disks to a spare box with a fresh install of freenas and i'm trying to find the pools again and so far no luck.
ZFS list, zpool status, zpool import. It all tells me it's empty or nothing is found. With 1 disk dead i guess i would be able to atleast find the other disk.
My inexperience with ZFS is really showing off and i have no clue on what to do. If somebody could shine some light on this case i would really appreciate it. I have partial backups but some of the files were in the process of getting copied and i would like to get those back.
Thanks for the help. Mike
