JavaScriptDude
- Nov 5, 2011
I have a freenas box that I use to back ESX VMs onto one dataset while I use other datasets for other usecases. I don't have a SLOG yet and thus speed is poor due to ESX pushing sync writes to the NFS store on my freenas box.
If I created a separate dataset for the NFS share and set sync=disabled for just that dataset will I be able to contain corruption to just that dataset if I loose power mid-write or will the entire ZFS pool still be at risk to corruption?
