I am designing a system capable of working with 15 million (and growing) image files ranging from 100kb to 10mb. After some preliminary research, our first choice is ZFS on FreeNAS. I was hoping I could get the the communities plan on our proposed hardware and ZFS configuration. We recognize we're dealing with a few non-optional/odd configurations/requirements.
Disclaimer: I'm a Software Engineer; I typically do not work on the filesystem level so I apologize in advanced if anything mentioned below is woefully inaccurate in relation to ZFS.
Environment:
Concerns:
High Level Configuration
Based on my introductory research I think this may be a good starting point. As I mentioned above, I don't typically work at the filesystem level so I apologize if I am woefully inaccurate on anything below:
I would love to hear the communities feedback/suggestion on our above proposal. I am happy to provide any additional information that may be needed.
Thank you!
[1]
Example directory structure - none of the directory/filenames are normalized in any way.
Environment:
- Concurrent Connections: This is an internal application that will only be utilized by a few folks. It's safe to say there will never be more than 5 concurrent connections accessing this data. In most (95%) cases, only one or two users may be accessing this data concurrently.
- Network: This data will only be accessed internally on a 1GbE network, though a 10GbE network is in the works for systems that will read this data.
- Hardware: The hardware we have allocated for this project is a mixture of older enterprise grade hardware and consumer grade storage (great combination, I know).
Dell R720xd w/ 24x 2.5” bays
RAM: 128GB RAM (more can be allocated if needed)
CPU: 2x E5-2620 @ 2.20GHz
Storage:
8x2TB SSDs local storage (Crucial MX500)
1x500GB SSD for OS and Database (Crucial MX500)
RAID: H310 (IT Mode)
- In almost all cases, the data will be permanently stored on the drive after the initial write.
- The data will not be modified (edited, compressed, resized, etc) after the initial write.
- The directory structure of the data is non-optimal [1], due to the design of the application pulling this data, it is more or less immutable.
- The data should be read optimized which includes, but may not be limited to: random/sequential reads, directory listings, etc.
- There will be new images written to the file structure on a fairly regular basis, but the write performance is not much of a concern.
- Data will be processed (image hashing, facial recognition vectors, etc) and stored in a MySQL database via a few Docker Containers on the same box to maximize processing performance.
- Data will be read/consumed by the user via SMB (windows) or NFS (linux) mounts.
- Data will be written via SMB (windows) or NFS (linux) mounts.
- There is a significant number of identical files (conservative estimate is 20%, but it could be quite more), due to the design of the application pulling this data we cant delete the filenames.
- We have about 10TB worth of data currently.
- We do not intend for this data to grow rapidly, maybe 1TB a year.
- We typically do a full directory backup of the data every month.
Concerns:
- Since we're planning on using consumer grades SSDs (unless an argument can be made to use 2.5" spinners) we're concerned about the longevity of the drives (particularly with metadata thrashing).
- Is the hardware sufficient for this use case?
- We'd like to dedupe the data if its feasible (more on this in the configuration section below) if it will result in significant space savings.
- 1 pool
- 1 raidz1 vdev (8x2TB SSD) - this may eventually expand to 3 raidz1 vdevs of the same size (24 bay enclosure)
- compression=on - with lz4 compression, if this isn't enabled by default
- ashift=9 (4k block size)
- dedupe=on may be a pipe dream though. With 128GB RAM I think I can make this work (assuming 5GB metadata per 1TB storage). I may be better off writing a script that will simply create (potentially millions) of hard links for identical images instead.
- sync=disabled from what I understand, disabling sync effectively disables the SLOG which means I may lose up to 5 seconds (configurable?) worth of new data being copied in the event of a hardware failure. If this is the case, I am OK with a few seconds of new data loss as long as existing data on the system is safe.
- no SLOG - see sync=disabled explanation above
- no ZIL
- no L2ARC - I don't see any reason why this would be needed with SSDs?
Thank you!
[1]
+ root directory 1 - sub directory 1 - image 1 - image 2 - image 3 - ... - image n (where n is between 1 and 1,000+) - sub directory 2 - image 1 - image 2 - image 3 - ... - image n .... - sub directory n (where n is between 1,000 and 30,000) - image 1 - image 2 - image 3 - ... - image n + root directory 2 + ... + root directory 15
