Charlie Fineman
- Sep 6, 2014
Getting ready to replace an older Proliant running VortexBox. Been pretty happy with the appliancy feel of VortexBox but less keen on the storage options they've provided out of the box. I'd also like to place some additional VMs on this box... some utilities (and windows 'desktop', perhaps an MB3 server, etc) plus some experimental VMs (I'm a software guy and I frequently use VMWorkstation to create sandboxes for playing around with different stacks).
FreeNAS/ZFS + ESXi feels like it might be the right choice for me. I've read some of the caveats about using FreeNAS on top of ESXi but it looks like folks have successfully done this so I'm interested in giving it a go. I'll poke around more (not to mention experiment before laying down the final config) to see what pitfalls folks have encountered but if anyone feels like warning me off, now would be a good time!
Having said that, this is a hardware forum so let's get on to the sand-based aspects of this.... primarily I want to be comfortable this box will be able to run a small number of VMs (<10) comfortably without unduly harming the performance of the FreeNAS VM. Specifically it's ability to
- run/serve ZFS
- plex video to a couple clients
- stream music
- media ripping
- SuperMicro MBD-X10SL7-F-O
- e3-12X1-v3 (where X=3,4, or 7... not clear the 10% boost from 3->7 is with the 30% increase in $!)
- 32GB ECC (might scale back to 16GB for now and see if I need more... will probably stick with ECC since I'm not that $ conscious and some portion of the data I'll be managing is 'precious')
- For the time being will be reusing a
- big-arsed thermaltake case
- Either a 400W or 600W PSU (2 or 3 years old but I just bench-tested them and they seem fine)
- A bunch of random disks (will look into this separately... one concern I have with ZFS is pool management esp for heterogeneously sized disks... but that's a topic for another post)
- Eventually (maybe sooner rather than later given my parity needs) will add on a SAS extender (the RES2SV240 one of the posters referenced looks pretty tasty)
