MrHands
- Jan 7, 2016
I plan on upgrading my server, I have been using the asrock c2750d4i and it keeps failing, I've rma'd it bunch, and I know it's a common theme with this board. The voltage sensors go bad and the motherboard just doesn't post.
So I've decided to upgrade this and will use the rma'd c2750d4i for pfsense.
After doing some research the X10SDV-TLN4F (1540 four core version) ( https://www.servethehome.com/supermicro-x10sdv-tln4f-review-platform/) seems to meet my needs, just wanted to check there's no festering issues like the asrock c2550d4i and c2750d4i had, and that's it's all good to go with Freenas? I don't want to fall in the same pit twice.
