I’m planning my new FreeNAS build and it would be nice if you could give me some feedback on my planed setup. The System should replace an existing 6 HDD system (HGST Deskstar 7K400 drives). The system should be expandable and therefore could be a bit to large for the 6 disks of the initial setup. After considering the recommandation threads I was thinking about the following components:
Mainboard: X10SL7-F
Compatible to Haswell (Energy saving and powerfull), enough SATA ports onboard
CPU: E3-1220 v3 / E3-1230 v3
Not quite sure which one I should use, pools should be encrypted, but that should be no problem with both?
Power Supply: Seasonic G-450
Case: Coolermaster Stacker
I want to reuse an old Coolermaster stacker Case with 12 5,25” bays. I found Cremax Icy Dock MB074SP-1B Black Vortex (http://geizhals.de/cremax-icy-dock-mb074sp-1b-black-vortex-a1141531.html?hloc=at&hloc=de) hot swap bays which are quite affordable. Are there some (more professional) alternatives to this bays?
RAM:
For the RAM I’m not quite sure which one to pick. Using the supermicro compatibility list I found 8GB modules from Samsung (M391B1G73QH0-YK0 - http://geizhals.de/samsung-dimm-8gb-m391b1g73qh0-yk0-a1079291.html). I have also read about the CT4484984 modules from crucial in the thread in this forum which are a bit more expensive. Should I prefer one of them? I’m not quite sure if I will go 2 or 4 dims at the beginning.
That should be main parts of the new system. Is this a round setup or in some points overkill? Is there something missing?
Thanks to everyone!
Mainboard: X10SL7-F
RAM:
Thanks to everyone!
