Inspired by this thread, I wrote (shamelessly copying) a script using
sesutil. First time try scripting but looks pretty straightforward to me. Tried on my system and looks like it worked. What's your thought on this? If you tried it on your system, let me know how it workedCode:
if [ ! "$1" ]; then
echo "Usage: faildediskled.sh [pool] "
echo "Scan a pool, activate leds of failed drives"
exit
fi
pool="$1"
condition=$(/sbin/zpool status $pool | egrep -i '(DEGRADED|FAULTED|OFFLINE|UNAVAIL|REMOVED|FAIL|DESTROYED|corrupt|cannot|unrecover)')
if [ "${condition}" ]; then
echo "Pool unhealthy, scanning for failed drive(s)."
glabel status | awk '{print "s|"$1"|"$3"\t\t\t |g"}' > /tmp/glabel-lookup.sed
zpool status $pool | grep -vE "(REMOVED|$pool)" | awk -F'was /dev/' '{print $2}' | sed -f /tmp/glabel-lookup.sed | awk -F'p[0-9]' '{print $1}' | awk 'NF' >> /tmp/faileddisk.sed
zpool status $pool | grep -E "(DEGRADED|FAULTED|OFFLINE|UNAVAIL|REMOVED|FAIL|DESTROYED)" | grep -vE "($pool|NAME|mirror|raidz|stripe|logs|spares|state|was /dev/)" |awk -F'(DEGRADED|FAULTED|OFFLINE|UNAVAIL|REMOVED|FAIL|DESTROYED)' '{print $1}' | sed -f /tmp/glabel-lookup.sed | awk -F'p[0-9]' '{print $1}' | awk 'NF' >> /tmp/faileddisk.sed
#cat /tmp/faileddisk.sed
sesutil locate all off > /dev/null 2>&1
for faileddisk in $(cat /tmp/faileddisk.sed);
do
echo $faileddisk "failed, trying to blink LED."
sesutil locate $faileddisk on
done
rm /tmp/glabel-lookup.sed
rm /tmp/faileddisk.sed
else
echo "Pool healthy, turning off all LEDs."
fi
