BUILD Will this Hardware be suitable?
efeu
I'm planing to build a (heavy load) test environment and I want to reuse some of our already existing hardware (ie esxi hosts with fibre HA). The freeNAS should become the storage of this esxi cluster (three nodes).
My planed hardware:
AMD Epyc 7261
Supermicro H11SSL-NC (integrated Broadcom SAS3008 8x SAS 12Gb/s Controller)
8x 16GB LRDIMM DDR4
4x Samsung SSD PM1643 1.92TB, SAS 12Gb/s
Some USB Stick for freeNAS OS
As we do have some Brocade 300 Switches for our esxi hosts (with LPe12000 8Gb Fibre Channel Host Adapters) I want to use 2x QLogic QLE2562-CK Adapters for the freeNAS (yes I know we should upgrade to 40 or 100Gb/s with this setup, but for now I have to use it).
In this thread it is mentioned that the QLogic Adapter will not work with a LSI Adapters (which should be just a rebrand of the integrated SAS3008 one) in the same system. Can anyone confirm this, any suggestion on using other 12Gb/s IT-Mode-SAS Adapter or another Brocade 300 supported SFP+ Adapter? Or is the info in this thread just outdated? Would the same happen to a dedicated Broadcom SAS 9305-16i ?
Update:
I reconsidered my hardware choice and I think we'll get a TYAN TN70AB8026 (B8026T70AV8E16HR) with 16x U.2 NVMe + 8x SATA
Now I dont know which SSDs to take, I'm thinking about:
8x 3.2TB Intel® SSD DC P4610 in Striped RAIDZ
8x 4.0TB Intel® SSD DC P4510 in Striped RAIDZ
8x 3.84TB Micron 9200 PRO in Striped RAIDZ
Use case will be the Cluster Storage of ~140 VMs
Any suggestions?
Chris Moore
Chris Moore
I don't think the success of FreeNAS would be impacted by the change from the H11SSL-i to the H11SSL-NC board, so you should be fine. Just change the SAS controller to the IT mode firmware. That should be fairly easy.
efeu
Well the main question still is, will the QLogic FB Card and the SAS-Controller(s) will block each other?
Chris Moore
Sorry, I don't have any experience with QLogic FB.
I have used Chelsio and Mellanox 10Gb SFP+ fiber adapters on FreeNAS servers with no difficulty.
Hopefully there is someone else that can chime in on that.
efeu
Any suggestions?
