omcn7
- May 19, 2015
Greetings community thank you for clicking on the post :)
My SuperMicro Board X10SLL-F just fried. Not quite sure why. So now I am doing a "Forced" upgrade. My current FreeNAS build will need a new mainboard,CPU, and RAM.
My use case is, a Raidz2 pool
Hypervisor Server is running 11+ VMs on a Dell R710 with 11TB in a raid10 w/ 6x 4TB SAS drives . A second pool
The new hardware needs to be compatible with the following.
1x 4TB WD blue
1x 4TB seagate desktop HDD
3x 4TB WD red
1x 59GB SATA SSD - ZIL
4x 2TB WD red
3x 2TB Seagate barracuda
2x 3TB Dell Constellation SAS drives
All drives are SATA 5400 RPM except for the two SAS drives which are 7.2k
raidz mirror for boot 16GB usb and supermicro sataDOM
To connect all these drives I have
1x 9220-8i LSI
1x 9210-8i LSI
After spending the better part of two days I have seen that many have suggested:
Supermicro Micro ATX DDR4 LGA 1151 Motherboards X11SSM-F-O Suggested mother board
and
Intel Xeon E3-1230 Processors BX80677E31230V6 Suggested CPU
Although it is hard for me to tell if these parts are best for my use case. My old supermicro only had 8 PCI lanes to work with.
1.The motherboard failed while I was upgrading to add the second LSI card.
2. My previous FreeNAS ran for 2 years. I just backed up all the data locally, pool A and Pool B grew in the upgrade and Pool C has yet to be added.
3. This is also when I will be adding ZIL to pool A and Pool B
4. Pool B is encrypted and has all my files and NFS shares set. I have a local backup but it is not organized into the shares and datasets. To reload the pool would take a considerable amount of time.
5. Pool A is encrypted but I have not set up the iSCSI target yet
6. I will not be growing the pools for some time. I hope this system not be EOL before 5 years
7. I just bought 2 quad port NICs for iSCSI, I have not tested that setup yet. I went with quad port because on the 8x PCI limit of the intel C222 chipset with C236 I would have 20 PCI lanes.
8. I only run linux/unix on bare metal, I would like IPMI to work. Supermicro had some outdated java stuff that only ran on windows and you had to turn off every security feature in IE to get it to work, even then it was buggy. I am weary of trusting supermicro after this experience. I have never built with asrock before...
Questions:
Q1. For my use case how much ram do you suggest I go with? What speed? I have 32 GB of DDR3
Q2. After watching a recent video I learned that in a future release encryption before sending to cloud for off-site backup will be available I want to be sure that I have the correct CPU and crypto hardware that supports this. youtube video with @ChrisMoore of ixSystems What CPU do you recommend? https://youtu.be/brfncQ5jPoA
Q3. What mobo do you recommend? Asrock or supermicro?
Q4. For my purposes do you suggest quad NICs or Chelsio 10GB cards? (FreeNAS and my hypervisor server are in the same rack).
Q5. I already have the SSDs, for my use case does ZIL make sense, will it speed up transfers?
Q6. What is the most economical way to meet my use case requirements?
I have done a lot of research and googling. I wanted to reach out and get involved in the community. I would really appreciate your valuable input. Thank you.
I read the forum rulez but I am a N00b to this forum (although I have read a lot going back to 2012 when I first started using FreeNAS) if anything is formatted incorrectly, kindly lmk.
pool A w/ ZIL SSD for an iSCSI target as backup of large datasets (VMDKs) for Type 1 hypervisor snapshots (testing ProxMox, ESXi and XCP-NG). Hypervisor Server is running 11+ VMs on a Dell R710 with 11TB in a raid10 w/ 6x 4TB SAS drives . A second pool
pool B for NFS raidz2 w/ ZIL, A third pool pool Craidz mirror as another NFS share. All the pools use encryption keysThe new hardware needs to be compatible with the following.
Pool-A Raidz2 w/ ZIL1x 4TB WD blue
3x 4TB WD red
Pool B RaidZ2 w/ ZIL4x 2TB WD red
Pool C2x 3TB Dell Constellation SAS drives
1x 9220-8i LSI
1x 9210-8i LSI
and
Before answering my questions it is important to note the following1.The motherboard failed while I was upgrading to add the second LSI card.
Questions:
