preginald
- Jun 19, 2012
Hey folks, I may have performed a royal rookie mistake and I have a couple of questions but first let me frame my situation.
Lets say for example I create a new zpool (on FreeNAS-8.0.4-RELEASE-p2-x86 (11367) / Platform Intel(R) Pentium(R) 4 CPU 2.80GHz) and labeled it 'bigboy' which creates a new folder in the filesystem as such '/mnt/bigboy'.
Now lets say I created a new folder labeled 'media' under the '/mnt/bigboy' folder which results in '/mnt/bigboy/media'.
Next I rsync about 1TB of files (from a desktop computer on the lan) into the '/mnt/bigboy/media/' folder.
Question 1.
If I use the FreeNAS gui to 'Create ZFS dataset' and labeled this new dataset 'media' which subsequently goes to create a folder under '/mnt/bigboy/' which results in '/mnt/bigboy/media/' will I lose the data that I originally rsynced into the '/mnt/bigboy/media/' folder I created?
The reason I ask this is because the content in the '/mnt/bigboy/media/' is now showing 112.0 KiB (0%) Used however the '/mnt/bigboy' shows 776.5 GiB (85%) used. I used ssh and listed the '/mnt/bigboy/media' directory and there are 0 files or directories recursively. Please refer to screenshot below.
Question 2.
Is there a way for me to undo and get back my data in the original /mnt/bigboy/media' folder?
Cheers, Pete
Question 1.
Question 2.
Cheers, Pete
