Charles Frank
- Dec 24, 2014
Hi folks,
Well, following advice on the forums about whether to go QNAP or FreeNAS, I bit the bullet and ordered components for a FreeNAS server - my first. The build went OK, and after a few reinstalls as I got to play with the software I felt comfortable enough to start copying my data across to get more of a feel for a 'proper FreeNAS setup' in a testing environment.
Now, up to this point everything SEEMED to be OK. But after several hours of copying data across (at the rate of 20-30Mb/s off my old Netgear ReadyNAS Duo...groan) I ran into a problem. Up to this point everything had been going fine - datasets were created, permissions set, CIFS working fine with drive shares mapped on my main computer - but once I had a couple terabytes of data on the new NAS things went rapidly downhill. There were times where the web console responded very sluggishly and it would take a reboot to sort it - but the main issue was that the NAS itself seemed to be having issues with the RAID array. Opening up My Computer could leave me with a blank, unresponsive window for 10-20 seconds before the drive icons (local and mapped) would appear. Double-clicking on one of the mapped network icons could work instantly but could also take several seconds before showing me the contents of the drive (the same issue with directories too). If I play media, like a movie, sometimes I can skip through it fine, with the film moving instantly to the point I've selected - other times it freezes for several seconds before 'catching up'. These issues aren't constant - but it's like everything works fine for 30 seonds, then it'll glitch, then back to normal for 20 seconds, then glitch etc.
I'm using a Supermicro X10SL7-F (BIOS 2.00, IPMI 1.42) with the LSI controller flashed to IT firmware 16 along with an Intel Xeon 1240V3 Processor, 16GB of Crucial ECC RAM, 6x3Tb HGST Deskstar NAS drives and a Seasonic G Series 550W PSU all in a Fractal Design Node 804 case. I'm using the latest (Dec 31) 9.3 STABLE build, patched with the latest updates installed and mirrored on 2 Sandisk Cruzer USB 16Gb drives (installed on an internal dual drive riser on the internal USB header). I have link aggregation set up for the dual onboard gigabit NICs (plugged into a Netgear GS108Tv2 switch). The NAS reports that everything (including the HDDs) is fine, but I have started doing some more detailed testing - redid the CPU and RAM last night with Memtest86 and they passed, need to redo the HDDs now.
If anyone has any ideas I'd really appreciate the help - I'm completely new to *ix/FreeNAS so I'm struggling a bit now if I'm honest as I've pretty much exhausted my own knowledge here...
