I am new here, and to TrueNAS, be gentle. ![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I work for a small business that tasked me with building a TrueNAS as our current NAS appliances don't work with SEDs. The Supermicro 6048R-E1CR36N is already purchased and populated with Xeon CPUs, 400GB+ of memory, 16x 12TB 7200RPM SAS12gbps SEDs, and 2x 400gb SAS12gbps SSDs. The server boots and all the drives are visible on the (about to be junked) raid controller.
I need to identify the best possible HBA card(s) for the system. A redundant, dual HBA, setup isn't required but the cards seem reasonably priced. Throughput is the main concern. Early next year I'm planning a networking upgrade from 10gbe to 100gb fiber. Getting the correct cables to connect the HBA to the backplane(s) is also a worry.
I had planned to setup the array similar to RAID 10. The SSDs were meant as mirrored system drives, but I believe that they might be better used as read/write cache drives. Any help you can provide would be appreciated. I feel that I'm pretty close, just looking for the right HBA and array config to move forward. Thanks!
