What is the correct firmware version for LSI 9305-24i
xnaron
I've got an LSI 9305-24i that I'm debugging and I want to make sure I am using the correct firmware version. Can anyone confirm?
I am running 16.00.12.00 SAS3224-IT
I've ruled out cables and backplane and either the HBA is bad or I've got an incompatible firmware. Same cable, backplane and hard drive position detects the drive in one HBA port but not another. Some ports yield CAM errors. It's very possible this card is toast but want to rule out firmware.
Thanks,
Brendin
serverboy
Hi
I am also using the same card. These are the details of my card.
Avago Technologies SAS3 Flash Utility
Version 16.00.00.00 (2017.05.02)
Copyright 2008-2017 Avago Technologies. All rights reserved.
        Adapter Selected is a Avago SAS: SAS3224(A1)
        Controller Number              : 0
        Controller                     : SAS3224(A1)
        PCI Address                    : 00:02:00:00
        SAS Address                    : 500062b-2-0299-1697
        NVDATA Version (Default)       : 10.00.00.03
        NVDATA Version (Persistent)    : 10.00.00.03
        Firmware Product ID            : 0x2228 (IT)
        Firmware Version               : 16.00.12.00
        NVDATA Vendor                  : LSI
        NVDATA Product ID              : SAS9305-24i
        BIOS Version                   : 08.37.02.00
        UEFI BSD Version               : 18.00.03.00
        FCODE Version                  : N/A
        Board Name                     : SAS9305-24i
        Board Assembly                 : 03-25699-02004
        Board Tracer Number            : XW84190355
        Finished Processing Commands Successfully.
        Exiting SAS3Flash.
Had some weird issues similar to what you had but only with one drive.
Sep 13 18:23:23 S-STORE01 mpr0: Controller reported scsi ioc terminated tgt 11 SMID 1249 loginfo 31110d01
Sep 13 18:23:23 S-STORE01 (da11:mpr0:0:11:0): WRITE(10). CDB: 2a 00 07 59 8f 20 00 08 00 00
Sep 13 18:23:23 S-STORE01 (da11:mpr0:0:11:0): CAM status: CCB request completed with an error
Sep 13 18:23:23 S-STORE01 (da11:mpr0:0:11:0): Retrying command, 3 more tries remain
Sep 13 18:23:24 S-STORE01 (da11:mpr0:0:11:0): WRITE(10). CDB: 2a 00 07 59 8f 20 00 08 00 00
Sep 13 18:23:24 S-STORE01 (da11:mpr0:0:11:0): CAM status: SCSI Status Error
Sep 13 18:23:24 S-STORE01 (da11:mpr0:0:11:0): SCSI status: Check Condition
Sep 13 18:23:24 S-STORE01 (da11:mpr0:0:11:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
Sep 13 18:23:24 S-STORE01 (da11:mpr0:0:11:0): Retrying command (per sense data)
Sep 13 18:26:03 S-STORE01 mpr0: Controller reported scsi ioc terminated tgt 11 SMID 298 loginfo 31110d01
Sep 13 18:26:03 S-STORE01 (da11:mpr0:0:11:0): WRITE(10). CDB: 2a 00 0a 00 19 a0 00 08 00 00
Sep 13 18:26:03 S-STORE01 (da11:mpr0:0:11:0): CAM status: CCB request completed with an error
Sep 13 18:26:03 S-STORE01 (da11:mpr0:0:11:0): Retrying command, 3 more tries remain
Sep 13 18:26:04 S-STORE01 (da11:mpr0:0:11:0): WRITE(10). CDB: 2a 00 0a 00 19 a0 00 08 00 00
Sep 13 18:26:04 S-STORE01 (da11:mpr0:0:11:0): CAM status: SCSI Status Error
Sep 13 18:26:04 S-STORE01 (da11:mpr0:0:11:0): SCSI status: Check Condition
Sep 13 18:26:04 S-STORE01 (da11:mpr0:0:11:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
They went away after changing the cable but today I was adding some more drives to the remaining slots I had an it came back again.
Oct  8 14:24:35 S-STORE01 mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x002b> enclosureHandle<0x0001> slot 16
Oct  8 14:24:35 S-STORE01 mpr0: At enclosure level 0 and connector name (    )
Oct  8 14:24:35 S-STORE01 da16 at mpr0 bus 0 scbus0 target 16 lun 0
Oct  8 14:24:35 S-STORE01 da16: <ATA ST14000NE0008-2J EN01> Fixed Direct Access SPC-4 SCSI device
Oct  8 14:24:35 S-STORE01 da16: Serial Number ZHZ3HZ36
Oct  8 14:24:35 S-STORE01 da16: 600.000MB/s transfers
Oct  8 14:24:35 S-STORE01 da16: Command Queueing enabled
Oct  8 14:24:35 S-STORE01 da16: 13351936MB (27344764928 512 byte sectors)
Oct  8 14:24:35 S-STORE01 mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x002c> enclosureHandle<0x0001> slot 17
Oct  8 14:24:35 S-STORE01 da17 at mpr0 bus 0 scbus0 target 17 lun 0
Oct  8 14:24:35 S-STORE01 da17: <ATA ST14000NE0008-2J EN01> Fixed Direct Access SPC-4 SCSI device
Oct  8 14:24:35 S-STORE01 da17: Serial Number ZHZ5XBP8
Oct  8 14:24:35 S-STORE01 da17: 600.000MB/s transfers
Oct  8 14:24:35 S-STORE01 da17: Command Queueing enabled
Oct  8 14:24:35 S-STORE01 da17: 13351936MB (27344764928 512 byte sectors)
Oct  8 14:24:35 S-STORE01 mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x002d> enclosureHandle<0x0001> slot 18
Oct  8 14:24:35 S-STORE01 da18 at mpr0 bus 0 scbus0 target 18 lun 0
Oct  8 14:24:35 S-STORE01 da18: <ATA ST14000NE0008-2J EN01> Fixed Direct Access SPC-4 SCSI device
Oct  8 14:24:35 S-STORE01 da18: Serial Number ZHZ4J5YV
Oct  8 14:24:35 S-STORE01 da18: 600.000MB/s transfers
Oct  8 14:24:35 S-STORE01 da18: Command Queueing enabled
Oct  8 14:24:35 S-STORE01 da18: 13351936MB (27344764928 512 byte sectors)
Oct  8 14:24:35 S-STORE01 mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x002e> enclosureHandle<0x0001> slot 19
Oct  8 14:24:35 S-STORE01 da19 at mpr0 bus 0 scbus0 target 19 lun 0
Oct  8 14:24:35 S-STORE01 da19: <ATA ST14000NE0008-2J EN01> Fixed Direct Access SPC-4 SCSI device
Oct  8 14:24:35 S-STORE01 da19: Serial Number ZHZ4F49X
Oct  8 14:24:35 S-STORE01 da19: 600.000MB/s transfers
Oct  8 14:24:35 S-STORE01 da19: Command Queueing enabled
Oct  8 14:24:35 S-STORE01 da19: 13351936MB (27344764928 512 byte sectors)
Oct  8 14:24:35 S-STORE01     (da19:mpr0:0:19:0): MODE SENSE(6). CDB: 1a 00 01 00 c0 00 length 192 SMID 689 Command timeout on target 19(0x002e), 60000 set, 60.213524600 elapsed
Oct  8 14:24:35 S-STORE01 mpr0: At enclosure level 0, slot 19, connector name (    )
Oct  8 14:24:35 S-STORE01 mpr0: Sending abort to target 19 for SMID 689
Oct  8 14:24:35 S-STORE01     (da19:mpr0:0:19:0): MODE SENSE(6). CDB: 1a 00 01 00 c0 00 length 192 SMID 689 Aborting command 0xfffffe01a72b63f8
Oct  8 14:24:35 S-STORE01 mpr0: Finished abort recovery for target 19
Oct  8 14:24:36 S-STORE01 (da19:mpr0:0:19:0): READ(10). CDB: 28 00 00 4c 06 c1 00 00 04 00
Oct  8 14:24:36 S-STORE01 (da19:mpr0:0:19:0): CAM status: SCSI Status Error
Oct  8 14:24:36 S-STORE01 (da19:mpr0:0:19:0): SCSI status: Check Condition
Oct  8 14:24:36 S-STORE01 (da19:mpr0:0:19:0): SCSI sense: ABORTED COMMAND asc:47,0 (SCSI parity error)
Oct  8 14:24:36 S-STORE01 (da19:mpr0:0:19:0): Retrying command (per sense data)
Oct  8 14:24:36 S-STORE01 (da19:mpr0:0:19:0): READ(16). CDB: 88 00 00 00 00 06 5d dc df c1 00 00 00 04 00 00
Oct  8 14:27:18 S-STORE01 mpr0: mprsas_prepare_remove: Sending reset for target ID 19
Oct  8 14:27:18 S-STORE01 da19 at mpr0 bus 0 scbus0 target 19 lun 0
Oct  8 14:27:18 S-STORE01 da19: <ATA ST14000NE0008-2J EN01>  s/n ZHZ4F49X detached
Oct  8 14:27:18 S-STORE01 (da19:mpr0:0:19:0): Periph destroyed
Oct  8 14:27:18 S-STORE01 mpr0: No pending commands: starting remove_device
Oct  8 14:27:18 S-STORE01 mpr0: clearing target 19 handle 0x002e
Oct  8 14:27:18 S-STORE01 mpr0: At enclosure level 0, slot 19, connector name (    )
Oct  8 14:28:50 S-STORE01 mpr0: Found device <881<SataDev,Direct>,End Device> <6.0Gbps> handle<0x002e> enclosureHandle<0x0001> slot 19
Oct  8 14:28:50 S-STORE01 mpr0: At enclosure level 0 and connector name (    )
Oct  8 14:28:50 S-STORE01 da19 at mpr0 bus 0 scbus0 target 19 lun 0
Oct  8 14:28:50 S-STORE01 da19: <ATA ST14000NE0008-2J EN01> Fixed Direct Access SPC-4 SCSI device
Oct  8 14:28:50 S-STORE01 da19: Serial Number ZHZ4F49X
Oct  8 14:28:50 S-STORE01 da19: 600.000MB/s transfers
Oct  8 14:28:50 S-STORE01 da19: Command Queueing enabled
Oct  8 14:28:50 S-STORE01 da19: 13351936MB (27344764928 512 byte sectors)
Oct  8 14:28:50 S-STORE01     (da19:mpr0:0:19:0): MODE SENSE(6). CDB: 1a 00 01 00 c0 00 length 192 SMID 609 Command timeout on target 19(0x002e), 60000 set, 60.32013045 elapsed
Oct  8 14:28:50 S-STORE01 mpr0: At enclosure level 0, slot 19, connector name (    )
Oct  8 14:28:50 S-STORE01 mpr0: Sending abort to target 19 for SMID 609
Oct  8 14:28:50 S-STORE01     (da19:mpr0:0:19:0): MODE SENSE(6). CDB: 1a 00 01 00 c0 00 length 192 SMID 609 Aborting command 0xfffffe01a72aee78
Oct  8 14:28:50 S-STORE01 mpr0: Finished abort recovery for target 19
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): READ(6). CDB: 08 00 00 02 20 00
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): CAM status: SCSI Status Error
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): SCSI status: Check Condition
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): SCSI sense: ABORTED COMMAND asc:47,0 (SCSI parity error)
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): Retrying command (per sense data)
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): READ(16). CDB: 88 00 00 00 00 06 5d df ff df 00 00 00 20 00 00
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): READ(10). CDB: 28 00 00 4c 06 c1 00 00 04 00
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): READ(10). CDB: 28 00 00 8c 06 c1 00 00 04 00
Oct  8 14:28:51 S-STORE01 (da19:mpr0:0:19:0): READ(10). CDB: 28 00 00 8c 06 fe 00 00 01 00
Oct  8 14:29:51 S-STORE01     (da19:mpr0:0:19:0): SERVICE ACTION IN(16). CDB: 9e 10 00 00 00 00 00 00 00 00 00 00 00 20 00 00 length 32 SMID 470 Command timeout on target 19(0x002e), 60000 set, 60.269963126 elapsed
Oct  8 14:29:51 S-STORE01 mpr0: At enclosure level 0, slot 19, connector name (    )
Oct  8 14:29:51 S-STORE01 mpr0: Sending abort to target 19 for SMID 470
Oct  8 14:29:51 S-STORE01     (da19:mpr0:0:19:0): SERVICE ACTION IN(16). CDB: 9e 10 00 00 00 00 00 00 00 00 00 00 00 20 00 00 length 32 SMID 470 Aborting command 0xfffffe01a72a2250
Oct  8 14:29:55 S-STORE01 mpr0: Finished abort recovery for target 19
Oct  8 14:29:55 S-STORE01 (da19:mpr0:0:19:0): READ(10). CDB: 28 00 00 4c 07 40 00 00 01 00
Oct  8 14:29:55 S-STORE01 (da19:mpr0:0:19:0): CAM status: SCSI Status Error
Oct  8 14:29:55 S-STORE01 (da19:mpr0:0:19:0): SCSI status: Check Condition
Oct  8 14:29:55 S-STORE01 (da19:mpr0:0:19:0): SCSI sense: ABORTED COMMAND asc:47,0 (SCSI parity error)
Oct  8 14:29:55 S-STORE01 (da19:mpr0:0:19:0): Retrying command (per sense data)
Oct  8 14:29:55 S-STORE01 (da19:mpr0:0:19:0): READ(16). CDB: 88 00 00 00 00 06 5d dc df ff 00 00 00 01 00 00
I have booted in to the HBA card and it can see all the cards fine there but that particular card is being recognised as a SATAII drive.
That particuar slot no matter what I insert is being recognised as SATAII.
Think my issue is a dodgy backplane.
I have created a pool though and ran a few benchmarks it hasn't thrown any errors so lets see how it goes.
I believe this firmware we both have is correct and is the latest.
