ewhac
- Aug 20, 2013
This behavior has been annoying me ever since I built my new box a while ago; namely, getting HDD SMART status via
Previously, I thought it was just something peculiar about the motherboard (and no, I couldn't tell you how I came to think that). But then the other night I did a
All SMART reports are clean, and the pools are fine. Indeed, it just successfully completed a resilver when I staged a failed drive test and swapped one of them out with a cold spare.
Anyone ever seen this sort of thing before?
smartctl
is slow. I mean, really slow -- between one and two seconds for a full -a or -x report. The output pauses as the various sections are printed out. Moreover, while this is going on, access to the SATA bus is effectively stopped. Almost no I/O transactions are happening while something holds the SATA bus getting the SMART data out. So when smartd
does its periodic check, volume access is pretty much stalled until it gets through all six spindles.Previously, I thought it was just something peculiar about the motherboard (and no, I couldn't tell you how I came to think that). But then the other night I did a
smartctl -x
by hand on the boot drive, which is a small SSD from a different manufacturer, and the complete report blasted out instantly. So now I'm starting to wonder if there's something amiss with the HDDs.All SMART reports are clean, and the pools are fine. Indeed, it just successfully completed a resilver when I staged a failed drive test and swapped one of them out with a cold spare.
